Technical, repair and troubleshooting
Forum | Topics | Posts | Last Posts |
![]() Electrical | 2162 | 26793 | Instrument Pod I... Today at 2:45 pm jjefferies ![]() |
![]() Frame, fairing and wheels | 1684 | 18424 | Gear shifter pro... Sun Sep 01, 2024 4:00 pm jbt ![]() |
![]() Engine and transmission | 2153 | 29694 | Really rough idl... Wed Sep 04, 2024 1:36 am amart0300 ![]() |
![]() How to – Article from you telling others how to do a specific job | 217 | 1853 | Clearing a sun f... Sat Aug 24, 2024 6:04 pm Point-Seven-five ![]() |
![]() Other K bricks (K75, K1100, K1) General discussion. | 263 | 3176 | K1 Flat Spot Today at 9:38 am jbt ![]() |
![]() Special tools and jigs | 75 | 847 | K Bike valve adj... Mon Jul 29, 2024 11:56 am Point-Seven-five ![]() |
![]() Everything about adding a chair(sidecar) on a K Bike..... | 136 | 1982 | Freighting a Sid... Tue Apr 23, 2024 7:33 pm Saxon7 ![]() |
![]() K bikes and trailers | 12 | 162 | Adding a Kamper ... Mon Oct 09, 2023 5:01 am Tranberg ![]() |
Go to page : 1, 2, 3 ... 8 ... 14
Topics [0]
![]() Front brakelight switch connector location on K100RSby kebe | 8 | 1229 | ![]() ![]() |
![]() Starting issue, low comp in all cylinders after head jobby sparkplug69 | 8 | 1257 | ![]() ![]() |
![]() Front brake woes, help pleaseby KiwiK100 | 15 | 1289 | ![]() ![]() |
![]() K100RT did not wake up well from the winterby celhardtruns while starter switch pressed, dies when starter switch released. | 6 | 1075 | ![]() ![]() |
![]() Fuel pressure monitor?by lucki | 13 | 1423 | ![]() ![]() |
![]() 1995 K75 starter issueby arbalestsound like (his description) motor spins, starter does not engage | 5 | 1249 | ![]() ![]() |
![]() Starting woes | fuel pumpby Ash | 1 | 1109 | ![]() ![]() |
![]() Fork leg coversby shinobi | 6 | 1177 | ![]() ![]() |
![]() k100 wiring harness K75by firstle | 4 | 1334 | ![]() ![]() |
![]() weak sparkby firstle | 5 | 1283 | ![]() ![]() |
![]() Tenet with Five Aces Mini - fuel meterby shinobi | 5 | 1364 | ![]() ![]() |
![]() Introduction to K1 misfireby Nsdean03 | 22 | 1551 | ![]() ![]() |
![]() K100RS 1986 No crank situationby DavidKSNo ground from Ignition control unit | 4 | 1455 | ![]() ![]() |
![]() Starter relay gone.. twiceby Gast1y | 6 | 1468 | ![]() ![]() |
![]() Can a starter motor still be faultyby Ian9 | 9 | 1301 | ![]() ![]() |
![]() Too rich to start, too lean to revby swampyankee | 35 | 1953 | ![]() ![]() |
![]() Spring collet in sumpby John1988 | 19 | 1810 | ![]() ![]() |
![]() Non-starting questionby WirelicBike cranks, doesn’t start | 12 | 1230 | ![]() ![]() |
![]() Gear Shift Indicator LCD Screenby gravelsandwichReplacing the old LCD with a new one | 8 | 1905 | ![]() ![]() |
![]() Oem fuel gauge for 1986 k100by Clintinz | 22 | 1664 | ![]() ![]() |
![]() Christmas Greetingsby moriarti | 17 | 1480 | ![]() ![]() |
![]() K1100 3 spoke front wheel questionby Joshrighthere | 9 | 1932 | ![]() ![]() |
![]() K100 vs M.unit vs Daytona gaugesby Clintinz | 24 | 1770 | ![]() ![]() |
![]() K75 Ignition switch positionsby Flippit | 6 | 1462 | ![]() ![]() |
![]() Battery trayby Fatpete1974uk | 13 | 1412 | ![]() ![]() |
![]() My mojo don't go[ 1, 2 ] by Bluebeemer85 K100 RT, 50K miles | 61 | 2404 | ![]() ![]() |
![]() Help requested to identify part please.by DrNocky | 7 | 1290 | ![]() ![]() |
![]() Indicator help pleaseby Clintinz | 4 | 1282 | ![]() ![]() |
![]() Luftmeister anti dive kit installby larsf | 4 | 1232 | ![]() ![]() |
![]() Replacing HES sensor on existing K75 plate. How to rivet on the replacement?by robmack | 9 | 1357 | ![]() ![]() |
![]() Dead ELECTRICSby moriarti | 2 | 1169 | ![]() ![]() |
![]() Air Intake Manifoldby gravelsandwichReplacing options | 1 | 1227 | ![]() ![]() |
![]() 1994 K1100LT rich idleby DnA Customsbike running rich at idle, blk plugs and exhaust | 2 | 1286 | ![]() ![]() |
![]() starter issue K100by Gary11relay fixes/options K100 1986 | 43 | 2146 | ![]() ![]() |
![]() Alternator regulator changeby Flippit | 4 | 1262 | ![]() ![]() |
![]() No clutch lots of trafficby fishboy316 | 10 | 1102 | ![]() ![]() |
![]() Troubleshooting a 1985 K100 that won't start/stay running[ 1, 2, 3 ] by TrailKlaus | 118 | 8479 | ![]() ![]() |
![]() No Crankby Ohhimark95 | 16 | 1727 | ![]() ![]() |
![]() Stop disk on clutch carrier shaftby attitudewhat does stop disk do on clutch housing? | 5 | 1498 | ![]() ![]() |
![]() Bep to breakout box b to motoscope proby nicmarshall46 | 1 | 2033 | ![]() ![]() |
![]() Clutch Cable Lengths?by tjh1985 | 3 | 1248 | ![]() ![]() |
![]() ICU overheating?by Alzaboy | 19 | 1584 | ![]() ![]() |
![]() Intermittent Stallingby davemadsenBike stalls (I frequently) when returning to idle | 29 | 3422 | ![]() ![]() |
![]() Where does this rubber go?by michaelvass | 18 | 1493 | ![]() ![]() |
![]() How do you remove the ignition control bush from the frame?by Clintinz | 5 | 1365 | ![]() ![]() |
![]() Possible coolant leak?by aakprrtTrying to track a leak down | 2 | 1375 | ![]() ![]() |
![]() Acid aluminum brightener darkened my engineby clappy | 2 | 1377 | ![]() ![]() |
![]() Frozen front caliper pistonsby Robpud | 7 | 1407 | ![]() ![]() |
![]() 93 K1100LT Microsquirtby mjones866 | 42 | 8295 | ![]() ![]() |
![]() k1100rs no brake at high rpmby Gergelyk1100rs no brake at high rpm | 4 | 1330 | ![]() ![]() |
Topics [50]
No new posts
New posts
New posts [ Popular ]
New posts [ Locked ]
