1Back to top Go down   Gear shifter problem (BSK rearset) Empty Gear shifter problem (BSK rearset) Sat Sep 08, 2018 1:08 pm
Jakey
Jakey
I have mounted BSK speedworks rearset. But as you can see on the picture below, there is something wrong. Is it mounted wrong or what to do to fix it? I was able to drive with it, but still it`s not good, and shifting gear wasn`t always perfect and tight
Gear shifter problem (BSK rearset) Img_2623
Gear shifter problem (BSK rearset) Img_2622
Gear shifter problem (BSK rearset) Img_2621
I would suggest a call to BSK. They are good at responding to queries.
Have you attempted to adjust the 'turnbuckle' mechanism in and out to keep the shift lever in a steady state position? I'm sure it needs to have a certain tension to stay aligned - it appears from your pictures, but not your description, to be slipping beyond the ideal position.
Do you see the alignment mark on the end of the splined shaft on your gearbox? That generally has to be aligned with the gap in the shift lever. Go to BSK's website and look at how they have mounted the lever of all of the race bikes. It is positioned at nearly twelve o'clock high. That may be yer problem.
TWB's right (as usual  Razz ) The gearbox-thingy-bit has to be perpendicular to the ground (i.e. pointing straight up) to get the  gearbox shift mechanism to work correctly. As it is at the moment, you're only getting a partial shift in the box and the dogs are not engaging correctly.
Jakey
Jakey
Thanks Smile I will look into it later this week an post a update Smile I saw someone has the `turnbuckle`oppsoite of mine. (at the bottom instead of the top like mine). Don`t know if it just the angle or if it`s the correct way to mount it.
Start with the basics.
6Back to top Go down   Gear shifter problem (BSK rearset) Empty Re: Gear shifter problem (BSK rearset) Sun Sep 16, 2018 12:52 pm
Jakey
Jakey
Thanks for the help, that was the problem Smile Works fine now.
7Back to top Go down   Gear shifter problem (BSK rearset) Empty Re: Gear shifter problem (BSK rearset) Sun Sep 16, 2018 12:55 pm
Oh, good. Very glad it was easy to sort.
Garfoid79
Garfoid79
Jakey wrote:Thanks for the help, that was the problem Smile Works fine now.
How did you fix this as I am having the same issues?
The four axles need to form a parallelogram. If the linking rod is too short, you can't shift properly.
That fills our fairest day.
