Clintinz
Clintinz
The bushes are really wobbly and the thread doesn’t seem to run right through like the battery bushes. I can’t seem to pull it or I screw it. I’d have to cut it off or is there something I’m missing?
How do you remove the ignition control bush from the frame? 460c0510
How do you remove the ignition control bush from the frame? 2212be10
Unscrew them; they are threaded into the frame. The rubber has probably split  which is why they are wobbly.You will probably have to use penetrating oil as they may be rusted based on the photo and you'll need pliers to get a good grip.
The threads on the battery bushes don't go through either. A lot of us have ended up with the lower thread corroded into the gearbox. There are ways of getting the buggers out Very Happy
madhatter
madhatter
i just recently experienced the same problem , the thread does not go right through the rubber so if you twist it too far it will tear in half as happened to me , then i got a small coal chisel and worked on moving the lower washer in the anti clockwise direction and it came loose . basically its just rusted up a bit so hard to move , try some penetrant and a small chisel and work on the lower washer to loosen it .
current - 86 K75s , 93 K75s , 07 CBR1000RR , 04 YZFR6 , 83 GSX1100SD Katana , 1997 XV Yamaha Virago 1100 , 1983 Kawasaki Z1000 J3 ,
previous XL100 , Suzuki SP370 , GPZ550 , 81 GSX1100SD Katana , 98 Ninja 900
madhatter
madhatter
you can buy replacements on ebay , look under anti vibration mounts and rubber bobbins , or you can try your local car wrecker for commodore air filter box rubbers , any of the VN 3.8 models and later
6Back to top Go down   How do you remove the ignition control bush from the frame? Empty Rubber anti-vibration mounts Thu Dec 23, 2021 3:56 pm
redrockmania
redrockmania
A good source of moulded rubber mounts in Australia is Clark Rubber with a number of outlets around the country. If there is one nearby try them, prices are reasonable.
For those living in New Zealand the Clark Rubber equivalent is Para Rubber (subsidiary of Clark since acquisition in 1996) and they stock the same rubber products.
Last edited by redrockmania on Sat Dec 25, 2021 3:50 pm; edited 1 time in total (Reason for editing : adding additional relevant information)
