1 Clearing a sun faded windscreen Wed Aug 14, 2024 12:41 am
jjefferies
Don't know how well this will work with scratches. But in the process of restoring this 1990 Orange/Red K75S I wanted to clean up the windscreen. Not that it's useless but it definitely is not really meant to be looked thru. While at the paint store I spotted these little kits for cleaning/clearing up sun faded plastic headlight covers. As they were only $5.00 I decided to give it a try. The kit consists of two gloves, 1 pc of 3000 grit wet/dry sand paper(about 1/2 of what I would call a regular sheet) and two packets of a creamy substance. So I wet sanded both sides of the windscreen. It is a relatively small screen. Then I toweled it mostly dry and let it finish air drying. This is covered in the instruction sheet. Then I opened one of the creamy material packets, actually a folded wet towel with material impregnated in it and using the edge of the wet towel covered both sides of the windscreen with overlap between brushings. Waited 10-15 minutes and then used the other packet to do it again. After drying completely I found that the yellowing had been largely removed and I was able to see through it. Would not recommend this for a windscreen you need to be able to look through. But for one which you can look over and if you prefer a clear screen as opposed to painting it, I thought it did a reasonable job. Now I found this in the US but would expect something similar to be available anywhere.
J.
J.
