1 Instrument Pod Issues/Repair Fri Sep 06, 2024 5:41 pm
jjefferies
So I'm almost getting the restoration of this "Orange" K75S working. (Actually it's Red but a tad more orange than my old "Red" bike). Now I was seeing a couple of problems with the instrument pod. The problems are:
1.) Clock has the top row of the matrix of dots creating numbers fading in and out.
2.) The gear indicator shows the numbers "2", and "4" messed up, and number 5 is seen as "6".
Hoping it was simply oxidation from sitting for 10 years I took the instrument pod off the bike and opened it up. First off I found the FPCB (flexible PCB) cable had a hole in it. Photo showing below. How they managed that I'm not sure. But it appears to be close to one of the mounting bolt holes so I have my suspicions. But I've begun isolating the two sides of the broken connecting wire for a permanent fix but in the meantime just ran a wire between the appropriate sides of two Green bulbs jumping over the hole as a temporary fix.
As a check I plugged in a Pod from a K100. The clock issue went away. I take this to mean it is simply oxidation. But the gear indicator issue is still present. So I'm guessing that the problem may not be in the Inst. Pod but may be where the sensor fits on the gear box or the sensor itself is the problem. I've never messed with this feature before. So Helpful Suggestions/Comments are solicited. Can you get to the location easily and is cleaning the sensor difficult?
thanks J.
picture of the broken FPCB cable.
thanks J.
