1Back to top Go down   No juice going to injectors Empty No juice going to injectors Sat Sep 14, 2024 6:48 pm
letsgetpractical
letsgetpractical
there is no signal going to injectors.  Checked fuses, relay, fuel rail has good pressure.  What wires/ component failure could cause this?
I own a 1985 KRT 100 Bmw
2Back to top Go down   No juice going to injectors Empty Re: No juice going to injectors Sat Sep 14, 2024 9:12 pm
The injectors should have power to them at all times, the firing is regulated by a ground pulse from the ECU. If you are using a digital meter the length of the ground pulse is not long enough to register a reading. the pulse is measured in micro seconds.
