1 Instrument Cluster Tue Feb 22, 2022 2:05 am
Bazza
I have just purchased an 1984 K100RS last Thursday, the plan is to clean it up and put it on Historic Rego.
There's not a lot to do as the bike is not too bad, a bit rough round the edges but it's all there and it's all original from looking it over.
I've pull the instruments off to replace the Hazard switch and trip meter knob which I broke straightening the faring mount(yes I know I should have taken them off first)I was going to buy a second cluster for parts but they do seem a tad on the expensive side so I decided not to, but what I found while searching was the amount of different pins numbers there are between the models, none of which match mine with 23 pins and that's in the cluster and on the connecters from the ECU itself so it must be original, right.
It has no extras that I can see, it looks like a basic K100RS, it's even the Pre 95 unleaded model, so does anyone know why it would have 23 pins in the connections.
Cheers Baz.
1984 K100RS,2007 R1200GS, 1973 Kawasaki H2-A Triple
