1 Fixing my Instrument Cluster Sat May 04, 2013 10:10 am
nitrogen
Greets everybody.
So I'm in the process of fixing my OEM instrument cluster. It's suffered water damage and has fried a PCB and FFC (flexible flat cable). Additionally, the gear indicator LCD display is cracked but the board it's mounted on seems to be in perfect working condition.
The user-end problems with the instrument cluster are:
1) No gear number indicator.
2) Non-functional speedometer/odometer.
3) No backlighting at all.
4) No "low petrol" light.
5) Clock often goes off and resets itself.
This is what I found when I opened up the cluster:
(larger image)
Pretty awful. Initially, I thought this was the speedometer controller (the PCB). Reading a few threads on here, a couple of people suggested it's actually the tachometer controller with references to Realoem indeed showing it as the tachometer controller. Funnily enough, my tachometer works perfectly fine, yet this board is severely damaged, so I'm still willing to believe it's for the speedometer.
I've probed the contacts around the area and there's lots of completely dead leads from where it's corroded and blown, so I expect certain things not to function.
I've seen the PCB in question to buy on Motorworks, but I'm hoping to salvage it if possible just to save myself £40.
Next up, LCD gear position indicator:
Like I said, the board the LCD display sits on seems to be of perfect working order as it still attempts to display something on the dysfunctional broken LCD display.
Anybody have an old instrument cluster lying around where they can sell me that tiny little LCD display? I was thinking about replacing the LCD display with an LED 7 segment display to make it more interesting. I believe the LCD segments are running on 5VDC, not sure, but if that is the case, I was thinking of wiring it in with resistors on the segments as the LED one runs on 2VDC or something.
I've seen the gear position indicator (with the board) on Motorworks for £30.
As for lights not lighting up, that could be because of the FFC being burnt. All the bulbs actually work as I've tested. The connectors that go into the back of the instrument cluster need some attention so we'll see what happens.
Once I've finished with all of this and put it back together, I'll waterproof the unit good and proper, maybe change the cover completely as there are cracks in the clear viewing plastic on the front.
So, um, if anybody has any low-cost tips or is willing to sell me a couple of small parts that I require, then let me know?
Thanks.
Nitrogen.
(larger image)
Thanks.
Nitrogen.
