1Back to top Go down   How do you get to the battery? Empty How do you get to the battery? Mon Jul 22, 2013 10:22 am
larrikin
larrikin
How do you get to the battery? I've told there is a 10mil nut somewhere, but I can not find it.
How do you get to the battery? Au-log11How do you get to the battery? Au-log11
88 BMW K100RS
It increases my paranoia
Like lookin' at my mirror and seein' a police car
2Back to top Go down   How do you get to the battery? Empty Re: How do you get to the battery? Mon Jul 22, 2013 11:49 am
Ajays
Ajays
Larrinkin,
Goto left side of bike and unclip the harness that runs to the elict box.
Goto right side of bike and unplug the rubber retaining plug of elect box.
Goto left side of bike and remove elect box with the harness attached..do not unplug the harness.
Now toolbox is clear, lift the rear up and back to pull it off its locations.
Battery is now fully exposed. disconnect it and tilt it back slightly and lift it out following the line of the rear mudguard.
Whilst electic box is out, put a tie to keep the plug attached and it should never give you trouble.
Reassemble in reverse.
                                             Ajays
How do you get to the battery? Th_Kengine_gif
AJAYS
3Back to top Go down   How do you get to the battery? Empty Re: How do you get to the battery? Mon Jul 22, 2013 11:52 am
Under the seat......
Plastic tray behind the gas tank, remove the over, the lower tray comes out..comes out......
Before you do any more disconnect both terminals and make sure you do not short them across the frame with dire consequences for delicate electronics. These terminals on my LT were 10mm nuts.
Electronic control module also comes out but this varies with the model. On my LT it was positioned in the recess under the cover and I could lift it to one side and remove the tray. On my RT it is in a slide in shelf under the tray but part of the tray one piece moulding, it has to be disconnected and removed with the tray.
Underneath this you will see the battery with a metal plate across it.
Two crosshead long screws, one each side of the battery go down into the battery support tray.
Unscrew these, plate lifts off but on the right hand side it also holds the coolant expansion bottle in place. It will flop about but should be ok, just make sure when you put it back that the top of it is positioned under the dome in the battery retention plate.
You can now remove the battery but it may take a bit of wriggling to get it out. When you put it back make sure the breather is positioned correctly and also that the coolant expansion goes back correctly.
My seat was a quick detachable one and made the job easy. Looking at my RT I figure removing the seat might be needed to get the battery out.
Sounds complicated but its not.
A little tip. If you have the battery out its a 2 minute job to pull the starter and then have a cup of tea while you check the brushes/clean it....Only 2 allen bolts keep it in plus a 10mm nut on the electrical connection.
