1Back to top Go down   k100 wiring harness K75 Empty k100 wiring harness K75 Thu Apr 20, 2023 4:28 am
firstle
firstle
will the k100 wiring harness talk to the k75 ecu , ignition ? so can i use a k100 harness or part of on a K75 ? not sure but i do not think so would just like confirmation from here , members far more experience of playing with electrics here than i have . thanks craig
2Back to top Go down   k100 wiring harness K75 Empty Re: k100 wiring harness K75 Thu Apr 20, 2023 10:28 am
I never thought about it, but off the top of my head I would say the only difference is that the coil connections and the number of injector connectors will be different.  The number of injectors should be no big deal because they are all connected together.
The coil connections is where the wiring is a lot different because of the different number of coils and the wasted spark on the K100.
All the rest of the parts in a Jetronic system are the same and have the same pin assignments, so I gues if you can figure out the coil wiring you might be able to use a different harness.
Personally, I would get the correct harness.
3Back to top Go down   k100 wiring harness K75 Empty Re: k100 wiring harness K75 Thu Apr 20, 2023 11:00 am
The consequences of uncertainty when playing with engine electrics are limited mainly to converting your ride into an incendiary device, but at a certain stage in life, opportunities for adventures should be taken. Think of the memories you'll be creating!
Anyway, here's a diagram that relates to Point-Seven-five's considerations.
k100 wiring harness K75 Scree242
4Back to top Go down   k100 wiring harness K75 Empty Re: k100 wiring harness K75 Thu Apr 20, 2023 2:36 pm
Point-Seven-five wrote:I never thought about it, but off the top of my head I would say the only difference is that the coil connections and the number of injector connectors will be different.  The number of injectors should be no big deal because they are all connected together.
The Hall Effect Sensors and ICUs are different as well. On a 4 cylinder HES the sensors are directly opposed whereas on a K75 the sensors are offset.
k100 wiring harness K75 EVWXwO3
5Back to top Go down   k100 wiring harness K75 Empty Re: k100 wiring harness K75 Mon Apr 24, 2023 4:09 pm
Short answer; will not work.
k100 wiring harness K75 Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
