Technical, repair and troubleshooting
Forum | Topics | Posts | Last Posts |
![]() Electrical | 2162 | 26793 | Instrument Pod I... Today at 2:45 pm jjefferies ![]() |
![]() Frame, fairing and wheels | 1684 | 18424 | Gear shifter pro... Sun Sep 01, 2024 4:00 pm jbt ![]() |
![]() Engine and transmission | 2153 | 29694 | Really rough idl... Wed Sep 04, 2024 1:36 am amart0300 ![]() |
![]() How to – Article from you telling others how to do a specific job | 217 | 1853 | Clearing a sun f... Sat Aug 24, 2024 6:04 pm Point-Seven-five ![]() |
![]() Other K bricks (K75, K1100, K1) General discussion. | 263 | 3176 | K1 Flat Spot Today at 9:38 am jbt ![]() |
![]() Special tools and jigs | 75 | 847 | K Bike valve adj... Mon Jul 29, 2024 11:56 am Point-Seven-five ![]() |
![]() Everything about adding a chair(sidecar) on a K Bike..... | 136 | 1982 | Freighting a Sid... Tue Apr 23, 2024 7:33 pm Saxon7 ![]() |
![]() K bikes and trailers | 12 | 162 | Adding a Kamper ... Mon Oct 09, 2023 5:01 am Tranberg ![]() |
Topics [0]
![]() K75 injection failby GergelyK75 injection question | 3 | 1348 | ![]() ![]() |
![]() How old is your intank fuel hoseby Jamie64 | 2 | 1385 | ![]() ![]() |
![]() Hope this helps the old girl.by Jamie64 | 6 | 1491 | ![]() ![]() |
![]() Throttle Body Syncronisation (Raytech SyncoKing)by Jamie64 | 18 | 1732 | ![]() ![]() |
![]() K bike coolingby Jlz52204 | 2 | 1378 | ![]() ![]() |
![]() K100 First ride...then first push[ 1, 2 ] by BespokeVillainyDies when warmed up | 50 | 2581 | ![]() ![]() |
![]() Rear shock replacementby jjfishing | 5 | 1390 | ![]() ![]() |
![]() Oil in air boxby _corti | 2 | 1153 | ![]() ![]() |
![]() Need info on what to check to correct ABS faultby JonCarterRed triangle telltale on dash won't go out. 93 k1100rs | 3 | 1162 | ![]() ![]() |
![]() No start, has wet plugs and spark...by BespokeVillainy | 13 | 1667 | ![]() ![]() |
![]() Brakes and rear wheel gear oil questionby jjfishing | 10 | 1289 | ![]() ![]() |
![]() no vacuum line to fuel regulatorby attitudefuel regulator found with no vacuum line | 1 | 1129 | ![]() ![]() |
![]() K1100LT brake replaceby attitudebrake line from MC difficult to access | 0 | 1031 | ![]() ![]() |
![]() Throttle tube and cam discby TimK100right handlebar control | 8 | 1188 | ![]() ![]() |
![]() 1990 BMW K100 LT with ABSby magicflem1990 BMW K100 LT with ABS info please | 0 | 1091 | ![]() ![]() |
![]() How to repair a leaking fuel tank?by Guest | 28 | 7526 | ![]() ![]() |
![]() Water/oil pumpby Jibe | 7 | 1072 | ![]() ![]() |
![]() Rear brake amplifierby Kjell.Martinn | 17 | 1161 | ![]() ![]() |
![]() Uncontrolled cranking overby oldschool67 | 2 | 909 | ![]() ![]() |
![]() K1100LT Fuel Tankby brickrider2Faulty fuel cap? | 13 | 1652 | ![]() ![]() |
![]() Exhaust emission readingsby Jibe | 11 | 1120 | ![]() ![]() |
![]() Oil leakby Barnie68 | 13 | 1142 | ![]() ![]() |
![]() Troubleshooting a no-crank situationby Puffalot | 7 | 958 | ![]() ![]() |
![]() Help guysby Jibe | 15 | 1005 | ![]() ![]() |
![]() Trying to figure out this whining noiseby jjfishing | 9 | 1007 | ![]() ![]() |
![]() Whats under the seat............K100 RS 1990 16Vby svenokThere's got to be more? | 4 | 994 | ![]() ![]() |
![]() Starting problems on a 87 K100[ 1, 2 ] by Ccanov | 90 | 5573 | ![]() ![]() |
![]() Replacing Brake Lines (on ABS Model)?by Bonzo | 25 | 1329 | ![]() ![]() |
![]() Fuel system and old fuelby tedmckey | 5 | 883 | ![]() ![]() |
![]() Organizationby tedmckey | 13 | 987 | ![]() ![]() |
![]() charging lightby moriarti | 9 | 1065 | ![]() ![]() |
![]() The 4 Radio speakers on 1995 K1100 Touringby chirodenuse with an i phone | 2 | 882 | ![]() ![]() |
![]() Replacing rear brake rotor 1986 Kby RocknBlues | 4 | 1007 | ![]() ![]() |
![]() And after 100 miles I realize that I has lost a...by Caravaca | 10 | 1113 | ![]() ![]() |
![]() Instant gasketby Shoei | 11 | 1077 | ![]() ![]() |
![]() Recommend me a torque wrench.by Bonzo | 14 | 1822 | ![]() ![]() |
![]() Floodingby pgolav | 9 | 1154 | ![]() ![]() |
![]() Bmw k75s no spark. HELP!by jaimers | 18 | 3419 | ![]() ![]() |
![]() BMW Diagnose: Testing Instructions for K Modelsby robmack | 4 | 1165 | ![]() ![]() |
![]() another K100 running rough - reverse intake flow?by NickyNicky | 24 | 1449 | ![]() ![]() |
![]() Things to do in Lockdown #2 (electric avenue)[ 1, 2 ] by Suzi Q | 68 | 4022 | ![]() ![]() |
![]() Woops filled up with an ethanol blendby Matthew-Brisbane | 16 | 1738 | ![]() ![]() |
![]() Thermo fan not workingby K one zero zero | 5 | 904 | ![]() ![]() |
![]() Compression testby dakelvinatorwhat you think? | 13 | 3317 | ![]() ![]() |
![]() Bike Identificationby SamgageVehicle Codes | 2 | 877 | ![]() ![]() |
![]() BMW OEM heated gripsby brickrider2heated grips turn off on K1100LT | 4 | 968 | ![]() ![]() |
![]() BMW K100 only idles well on side stand!by wilbowont idle well on centre stand or when rolling to a stop | 7 | 1008 | ![]() ![]() |
![]() Front wheel bearing queryby Suzi Q | 9 | 1120 | ![]() ![]() |
![]() Gear lever extenderby Colin Press | 11 | 1076 | ![]() ![]() |
![]() Starts, runs and diesby rc2870 | 22 | 1557 | ![]() ![]() |
Topics [50]
No new posts
New posts
New posts [ Popular ]
New posts [ Locked ]
