  • View posts since last visit
  • View your posts
Technical, repair and troubleshooting
ForumTopicsPostsLast Posts
No new posts
Electrical
218126936restoration of t...
Thu Nov 21, 2024 2:01 pm
glennpm View latest post
No new posts
Frame, fairing and wheels
169218541Lighting upgrade...
Today at 10:16 am
Tranberg View latest post
No new posts
Engine and transmission
217329876Idling problem...
Mon Nov 18, 2024 9:54 am
No new posts
How to – Article from you telling others how to do a specific job
2191891The ultimate BMW...
Fri Oct 25, 2024 1:45 am
David Menzies153 View latest post
No new posts
Other K bricks (K75, K1100, K1) General discussion.
2633205cooling fan fuse...
Mon Nov 18, 2024 5:31 pm
tinyspuds View latest post
No new posts
Special tools and jigs
75847K Bike valve adj...
Mon Jul 29, 2024 11:56 am
Point-Seven-five View latest post
No new posts
Everything about adding a chair(sidecar) on a K Bike.....
1371991The ultimate sid...
Sun Oct 13, 2024 5:58 pm
Dai View latest post
No new posts
K bikes and trailers
12162Adding a Kamper ...
Mon Oct 09, 2023 5:01 am
Go to page : Previous  1, 2, 3, 4, 5 ... 9 ... 14  Next
Topics [0]
TopicsRepliesViewsLast Posts
No new posts
Fuel pump replacement today.
   by SniperX
201298Technical, repair and troubleshooting 4780-75Wed Jan 20, 2021 8:11 pm by Laitch View latest post
No new posts
Starting problems 86 k100 8v
   by bigminiandy
251428avatarSat Jan 02, 2021 6:29 am by nino View latest post
No new posts
Cool restoration video of a K ancestor
   by Woodie
0835Technical, repair and troubleshooting 5115-49Sun Dec 27, 2020 10:01 am by Woodie View latest post
No new posts
Rear Tire 130 or 140/Battlax A41
   by cycleman
192338Technical, repair and troubleshooting Avatar10Tue Dec 22, 2020 10:12 am by cycleman View latest post
No new posts
Just thinking...
   by Suzi Q
111101Technical, repair and troubleshooting 3479-77Fri Dec 04, 2020 10:55 am by Point-Seven-five View latest post
No new posts
Brake Caliper Bolts
   by gorio
31050Technical, repair and troubleshooting 3608-23Wed Nov 11, 2020 6:51 am by Dai View latest post
No new posts
Need Baffle Rebuild Suggestions
   by AUBIEBMW
 1985 K100RS baffle rebuild suggestions needed
171424Technical, repair and troubleshooting 4473-85Thu Nov 05, 2020 4:44 am by jbt View latest post
No new posts
Speedo not working correctly
   by Middleton
111056Technical, repair and troubleshooting 6032-16Mon Sep 21, 2020 5:03 pm by daveyson View latest post
No new posts
Tyre changer
   by indian036
131414Technical, repair and troubleshooting 3332-3Sat Sep 12, 2020 7:56 am by indian036 View latest post
No new posts
ignition lock contact
   by nino
372074Technical, repair and troubleshooting 6878-84Sun Sep 06, 2020 4:56 pm by keithnh View latest post
No new posts
1985k100
   by Noel1985k100
2872Technical, repair and troubleshooting 2613-80Thu Aug 20, 2020 3:56 pm by Arlina View latest post
No new posts
Voltage at Pin 1 Fuel injection controller plug.
   by Tomso
341369Technical, repair and troubleshooting Avatar10Sun Aug 09, 2020 4:48 pm by Tomso View latest post
No new posts
K75S Radials tyre pressures
   by SteveWilson
 Advice wanted
31127Technical, repair and troubleshooting 3281-79Sat Aug 08, 2020 10:02 am by Snod Blatter View latest post
No new posts
So I’m not the first, but can’t find if mounting the 5 lug rear k1200 wheel has been solved
   by MikeisonTV
21180Technical, repair and troubleshooting 5422-6Wed Jul 22, 2020 2:36 am by Suzi Q View latest post
No new posts
Yellow K revival
   by Nacs
21140Technical, repair and troubleshooting 3608-23Sun Jul 19, 2020 5:40 am by Dai View latest post
No new posts
Fuel pump removal from tank
   by keeper
55205Technical, repair and troubleshooting Avatar10Tue Jul 14, 2020 12:27 pm by moriarti View latest post
No new posts
No start issues
   by Built4comfort
201267Technical, repair and troubleshooting Avatar10Sun Jul 12, 2020 2:44 am by Built4comfort View latest post
No new posts
K100 RS Throttle Body Shaft Thread Size
   by Brett Glover
91142Technical, repair and troubleshooting Avatar10Wed Jun 24, 2020 7:01 am by Brett Glover View latest post
No new posts
Bell housing alternator bearing
   by smoll1
171604avatarSun Jun 21, 2020 1:44 pm by smoll1 View latest post
No new posts
Why do the strippers put the exhaust can on the right side?
   by duck
181588Technical, repair and troubleshooting 1061-14Sun Jun 14, 2020 9:11 pm by Rick G View latest post
No new posts
Tank badges removal
   by moriarti
41044Technical, repair and troubleshooting 679-39Fri May 29, 2020 6:48 pm by Tom G View latest post
No new posts
K75 issue
   by MikeisonTV
151891Technical, repair and troubleshooting 4780-75Fri May 22, 2020 5:52 am by Laitch View latest post
No new posts
fuel tank and line drain - help how-to
   by gurka
373088Technical, repair and troubleshooting 3479-77Wed May 20, 2020 9:11 pm by Point-Seven-five View latest post
No new posts
Front end wobble
 [ 1, 2 ] by DeanG
573502Technical, repair and troubleshooting 5142-60Tue May 05, 2020 11:36 pm by MartinW View latest post
No new posts
O Rings compound
   by Packo
41048Technical, repair and troubleshooting Avatar10Mon May 04, 2020 6:29 am by Packo View latest post
No new posts
Stripped banjo bolt hole
   by jpatrickleighton
61774Technical, repair and troubleshooting 1606-33Sat May 02, 2020 10:58 pm by Two Wheels Better View latest post
No new posts
Acewell md085-553 with BEP3.0 > warning light stays on
   by Suurtje74
01178Technical, repair and troubleshooting Avatar10Thu Apr 30, 2020 7:55 am by Suurtje74 View latest post
No new posts
hard to start, but wants to start but dies shortly, or dies when opening throttle...
   by Noisey
 Bike wants to fire, if the sprag will allow it, but will only run for a short time or upon opening throttle...
151608Technical, repair and troubleshooting Avatar10Sun Apr 26, 2020 10:59 am by bobliu View latest post
No new posts
Bike won't idle properly, please help!
   by bobliu
 Please educate me on what to do next!
31130Technical, repair and troubleshooting Avatar10Sun Apr 26, 2020 10:16 am by bobliu View latest post
No new posts
86k rs instrument seal
   by Flip2
2858Technical, repair and troubleshooting Avatar10Sat Apr 25, 2020 8:41 am by Flip2 View latest post
No new posts
Starting up the bike
   by Specialist
171716Technical, repair and troubleshooting Avatar10Tue Apr 21, 2020 3:00 pm by Specialist View latest post
No new posts
More things to do in lockdown when you're bored...
   by Suzi Q
261519Technical, repair and troubleshooting 5422-6Fri Apr 17, 2020 10:30 am by Suzi Q View latest post
No new posts
Gear Indicator flickering at Idle?
   by K-dawg
 HALL Sensor replacement
231444Technical, repair and troubleshooting 5142-60Mon Apr 13, 2020 9:28 pm by MartinW View latest post
No new posts
K75 shock
   by Aged speed freak
71205Technical, repair and troubleshooting 1012-65Thu Apr 09, 2020 6:30 pm by K75cster View latest post
No new posts
K75 Tank lines
   by jjefferies
 Question about lines in the K75 Gas Tank
0981Technical, repair and troubleshooting 2834-53Tue Apr 07, 2020 9:33 pm by jjefferies View latest post
No new posts
bit inside gas cap nose -- 1990 K1
   by bldrhouse
 have removed gas cap and replaced seals, but..
131200Technical, repair and troubleshooting 5142-60Tue Mar 03, 2020 3:27 pm by MartinW View latest post
No new posts
Starting issue
   by Russell M
61127Technical, repair and troubleshooting Avatar10Sun Feb 16, 2020 3:23 pm by Russell M View latest post
No new posts
Instrument/speedo conversion advise and guidance needed
   by jpatrickleighton
21632Technical, repair and troubleshooting 4780-75Thu Jan 30, 2020 11:51 pm by Laitch View latest post
No new posts
Won’t start and flooding
   by Wally!
91352Technical, repair and troubleshooting Avatar10Wed Nov 20, 2019 5:03 pm by Matthew-Brisbane View latest post
No new posts
K100 fuel injection
   by K100TRIKE
 K100 fuel injection
171586avatarTue Nov 12, 2019 6:46 am by 92KK 84WW Olaf View latest post
No new posts
Mix & Match?
   by tjh1985
91157Technical, repair and troubleshooting 2613-80Fri Nov 08, 2019 3:31 pm by Arlina View latest post
No new posts
F###! No Gears AND Bad Noise
   by tjh1985
412507Technical, repair and troubleshooting Avatar10Fri Nov 08, 2019 2:30 pm by volador View latest post
No new posts
Fuel cap spring
   by futech
91106Technical, repair and troubleshooting 963-6Sun Nov 03, 2019 6:19 pm by charlie99 View latest post
No new posts
Restricting a K100 for A2 License
   by DBRMN
343445Technical, repair and troubleshooting 5367-61Fri Nov 01, 2019 5:08 pm by DBRMN View latest post
No new posts
Tank/handlebar stop
   by futech
61261Technical, repair and troubleshooting 3060-8Mon Oct 28, 2019 3:39 pm by duck View latest post
No new posts
High idle
   by futech
21225Technical, repair and troubleshooting 3060-8Sun Oct 27, 2019 11:51 am by duck View latest post
No new posts
Tank pinhole leaks
   by futech
101795Technical, repair and troubleshooting 6414-4Sat Oct 26, 2019 9:12 pm by futech View latest post
No new posts
K100 workshop repair manual
   by Loris
21249Technical, repair and troubleshooting Avatar10Sat Oct 26, 2019 7:20 am by Loris View latest post
No new posts
New clutch cable issue
   by tjh1985
61108Technical, repair and troubleshooting 5901-9Tue Oct 22, 2019 4:10 pm by tjh1985 View latest post
No new posts
Winterizing My K100?
   by tjh1985
51049avatarMon Oct 21, 2019 6:26 pm by 92KK 84WW Olaf View latest post
Topics [50]
  Back to top
Users browsing this forum: None
  • No new posts No new posts
  • New posts New posts
  • New posts [ Popular ] New posts [ Popular ]
  • New posts [ Locked ] New posts [ Locked ]
