jjfishing
jjfishing
I'm replacing the rear rotor and brake pads on my 87 k100rs. I figured I'd change the rear wheel gear oil also. I looked in my manual and it says the rear wheel gear oil is 80 or 90 weight I believe. When I drained the oil it was clearly not gear oil. It was clean, but red like transmission fluid. I've only owned the bike for a few months, so I don't know the history of it. Is there a reason anyone knows of for there to be a different fluid other than traditional gear oil inside? Should I put gear oil in after there's been a different fluid in there? Also, is there a specific type of brake fluid I should use or anything I should be aware of with the rear brakes and rotor, it seems pretty straight forward. Thanks for any info.
Use the recommended gear oil that ATF is not suitable for helical cut gears. As for brake fluid any good brand DOT 4 fluid is suitable.
moriarti
moriarti
Don't trust PO, check gearbox oil as well.
moriarti wrote:Don't trust PO, check gearbox oil as well.
It's the reason I change all the fluids and do a complete service when I get a "new" bikes. There are people out there who have no business wrenching on a motorcycle.
moriarti
moriarti
EXACTLY
Got a point there Smile
A year ago had a Yamaha XV535 here, making strange noises.
Owner did a full service himself, been 500km since.
Saw it has enough "oil", altough it didn't look like oil.
Drained it, found coolant.
Enigine non-savable Evil or Very Mad
Brakes and rear wheel gear oil question  Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
jjfishing
jjfishing
Thanks for all the replies. I'm going to go ahead and change all the fluids.
Redline in the US make appropriate gear oil in hypoid GL5. No prizes for guessing what colour it is.
bad boy
bad boy
Point-Seven-five wrote:It's the reason I change all the fluids and do a complete service when I get a "new" bikes.  There are people out there who have no business wrenching on a motorcycle.
100% agreed
Cheerz, David
Brakes and rear wheel gear oil question  9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
yamaguzzi
yamaguzzi
If it were my bike I'd put in a good 90W gear oil,ride it 20 or so miles and drop it in a clean white container to have a look at it. Then,I would put in fresh 90w gear oil . Oil is cheap gears are not and it's better to be safe than sorry.
It's probably just Redline Gear oil.... it's red Laughing
I wouldn't worry too much about it. Just replace all your fluids so you have a baseline for all future servicing.
75w90 is recommended in the riders manual
DOT 4 brake fluid.
 Brakes and rear wheel gear oil question  Austra12    Fuel:  95 Octane
