1 rear brake sticking Wed 28 May 2014, 00:11
audibob
I noticed a rubbing sound from the rear brake recently. I removed the caliper and pads, and found when I pressed the pedal, both pistons would operate to the same degree,and then retract when the brake pedal was released. However, when I refitted the pads, I noticed the offside pad would run close to the disc, hence the sound, the nearside pad would contact the disc but on releasing the pedal pressure, the pad would retract twice the distance as the offside pad. I pumped the pedal a few times to try and get the nearside pad to stay closer to the disc , but it would always retract more than it needed to . My guess is that the offside piston is sticking therefore when the pedal is released. the retraction "action" is pulling the free piston back more. I have ordered a kit.
Anyone had the same problem? The hoses look good, I get good pressure on the pedal so hopefully just crud in the caliper.
On a perfect set up, given that the pads are not physically attached to the pistons, as they are on some car calipers, is it normal to hear some slight contact noise? Both my front pads/discs have very slight contact noise.
given the age of her, I may as well do the front calipers too.
Thanks for any replies
Bob
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
