1 Replacing rear brake rotor 1986 K Tue Apr 20, 2021 5:02 pm
RocknBlues
On my new to me bike the rear rotor has some rolling groves in it. Might be okay, the last owner was happy with the rotor.
But I'm going to replace it just for my peace of mind.
As I understand it I take off the caliper, remove the wheel and remove the rotor. I've seen a video where the guy was using a torch to heat up the 2 retaining bolts to make removal possible.
Next chane out the rotor and reinstall mounting bolts with blue locktite and torque to specs.
Put the tire back on and ride.
Think I'll also check and grease the final drive splines including removing the driveline and lubing all splines.
All of that should get done in under a couple hours first time doing it.
What lube do you use on the splines?
Have you filled the hollow driveshaft with silicone to keep the Grease from migrating up?
