1 Sticky transmission Thu Jun 13, 2013 12:36 pm
otto59
1985 K100. Jumps out of second gear and won't shift higher than second. Time to check the clutch spline lube?
But is transmission really faulty? You don't replace the fuel tank just because the cap is faulty, do you? Seems everything points to clutch spline lube by some of the shifting problem posts here. Anyone else have any ideas?ibjman wrote:Well, You'll be removing the transmission to repair it, so you can lube the clutch while it's out.
I suspect you need trans repairs. The good news is that there are a lot of good used transmissions out there for very reasonable money. So In My Opinion, it makes better sense to exchange it rather than repair it.
Regards, Ibj....
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Sticky transmission
Similar topics
