Go to page : Previous  1, 2, 3, 4, 5, 6 ... 11 ... 18  Next
View previous topic View next topic Go down  Message [Page 5 of 18]
201Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Wed Apr 09, 2014 2:52 am
floyd
Thanks to both Rick and Rob for the above to pieces of gold knuggety goodness...
Just swung by the bearing shop again and bid good morning to Sydneys grumpiest old men, where I ever so gratefully received my 2nd free 19x1.5 circlip. Hooray for local bearing shops.
As I arrived back at home I am greeted by an enormous box from motobins, sweet times indeed.
202Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Wed Apr 09, 2014 3:21 am
yippee !
203Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Thu Apr 10, 2014 7:51 am
floyd
floyd
Well, good news! I found the infamous "SAFE PLACE"!!!
And my important things are still there!!!
Its just, yesterday the postie delivered the brand new ones Id bought to replace the ones lost to the safe place!!
If anybody needs:
K1100 fork seals
K1100 fork gaitors
Oil/water pump kit
steering head bearings
Let me know!
204Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Thu Apr 10, 2014 12:02 pm
Plenty of 1100 owners in here floyd so stick em in a safe place till they contact you. Wink
205Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 11, 2014 1:24 am
floyd
floyd
robmack wrote:
... then on go the cleaned up K1100 throttle bodies and injectors (cleaned my the local brake mechanic in his ultrasonic cleaner) into the brand spanking new throttle body manifold rubbers
Floyd,   Have you a plan for fitting the TPS on the new throttle bodies?  If not, consider swapping the butterfly shaft in TB4 with an old one from one of the K100 throttle bodies.  Fitting the TPS will be a breeze afterwards.
Thanks heaps for that info and link robmack. Great stuff - will surely help me in the very near future
206Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 11, 2014 9:58 am
floyd
floyd
Very good few days really....managed to get the following done....
Got the gearbox all back together and it appears to be functioning ok.
Was a rainy day so the proceedings were forced to move in doors - luckily this conicided with the significant other and the flat mate both being away.,...
Around the World On a K100 - Page 5 Wp_00065
Changing gears can be a bit of a shit sometimes but I reckon when there is a bit of a load on the output shaft it should be rather nice. Hopefully I got the bearing preload and end float measurements and shim adjustments correct...time shall tell...
Around the World On a K100 - Page 5 Wp_00066
Today, the focus was on fitting the K1100 throttle bodies....
Thanks to an above post/link  from robmack, I was able to quickly and easily fit the K100 throttle position sensor to the K1100 TBs. This is done by swapping the butterfly shaft of the 4th throttle body from the 100 into the 1100. Easy.
K1100 TBs with K100 TPS - direct bolt on...
Around the World On a K100 - Page 5 Wp_00067
Here we have the K100 TBS on the K1100 TB's - also showing the fully renewed and cleaned K1100 injectors on the K100RS injector rail
EDIT: Thanks to RickG for the heads up, I have heaps of 46mm BMW clamps on hand to replace the dis possible 1 use jobbies.
Around the World On a K100 - Page 5 P1050020
I mounted them up into their brand new manifold rubbers (which I had fitted previously after cleaning up the mating surfaces etc etc) and quickly discovered and clearance issue with the throttle cable arm thingy that moves when the throttle is opened.
My solution to this may or may not be the correct one....
I had to remove TB #3 from each TB 'rack' and swap their respective throttle-arm-thingy-that-rotates-when-throttle-is-opened, and all other associated K100 throttle cable/FPR mounting hardware....This has solved the clearance issues obviously, however I think the 'balance' of the butterfly valves was thrown out in the process and I have played around with their adjustment screws to a point where they are all mostly sealed when throttle is closed. It seems I have run out of room on the adjustment screws....hmmm....
Around the World On a K100 - Page 5 P1050021
And here is where we are so far, as far as the assembly is concerned....
Around the World On a K100 - Page 5 P1050022
Around the World On a K100 - Page 5 P1050023
On top of all this, I took a bottle of nice red wine from Orange NSW to my new mate the brake mechanic at Marrickville - now he lets me use the press my self so I decided to press the steering stem out enough to remove the lower bearing. HOLY SHIT does that thing require some force to move! But, got it off I did...
207Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 11, 2014 10:12 am
For future reference I drive a thin knife blade under the bearing then progressively wider blades then a lever like a screwdriver and the bearing usually comes off. If that doesn't work weld a great big glob of metal onto the bearing inner and belt the crap out of it and the inner expands and flop off it comes.
Those shafts are usually shrunk in liquid nitrogen to get them into the triple clamp so its no wonder it was a touch reluctant.
208Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 11, 2014 10:14 am
floyd
floyd
RicK G wrote:For future reference I drive a thin knife blade under the bearing then progressively wider blades then a lever like a screwdriver and the bearing usually comes off. If that doesn't work weld a great big glob of metal onto the bearing inner and belt the crap out of it and the inner expands and flop off it comes.
Wow, should have asked first.
I think it twas the Haynes manual that recommended the method I adopted. Any chance of doing it damage this way?
On the topic of steering stems...
This is on the K1100 stem - as it was when I bought it....Any thoughts?
Around the World On a K100 - Page 5 P1050024
209Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 11, 2014 11:00 am
I wouldn't think you would do any damage to it and as for the gouge don't even worry about it that part of the stem would have very little stress and welding it would probably cause more harm than good.
It looks to me the sort of damage you would get from a forced steering lock but the lock on a K1100 is external at the top.
One more mystery that probably never be solved.
210Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 1:40 am
floyd
floyd
Ok, calling all experts....
Ive opened pandoras box and messed with things I should never have messed with and now lifes as we know it as in grave danger - you know how it goes...
Ive messed with ever possible thing that should not be messed with on the throttle bodies. I know, I know, you can sigh, moan, grumble and roll your eyes at the young newby all you like.....but NOw I have a good set of messed up throttle bodies and I NEED HELP Smile
How do I proceed? Is a motorcycle mechanic able to get them back into any kind of resemblance of balanced? Specifically, the little 8mm locknut and screw that is marked with paint and clearly should not be messed with. The balance of the throttle butterfly bits is all out of wack....I can get 3 out the four all closed up evenly, but the 4th stays open a little... should they all be totally closed, or just equal to each other?
I know they were done on a flow bench by nuclear physicists etc, but surely all hope is not lost....
211Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 2:01 am
Hmmm I did wonder about that.
They should all close completely. I'm not sure they use a flow bench but a jig for sure.
I found that the PO's idiot dealer mechanic had messed with mine (don't tell anyone else but it was Motohansa) and had to get them right again. They still aren't quite right and the idle is too high.
I held the butterflys open by the idle adj screw and got the one that opened with the throttle cable (#3 I think) to a point where the reverse end of a 1/16 drill bit just fitted then worked on the other 3 to get them to match.
I know that if you close the adjuster up too tight you get all sorts of problems.
I got them to the stage where they are good enough to work well but not spot on because I cant get the vacuum gauges to read evenly.
There was a write up done here on the subject but as usual I can't find it. It may have been mike p that did it.
I now have a second set that are untouched so will be using them and putting 3/4 of this set on the K75.
212Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 2:07 am
floyd
floyd
Thanks Rick.....
Bloody dickhead I am - was to impatient and rushed into it - you know how it is sometimes....
Anyways, I will play with them, but considering I could pick up another set for 100 or less, I may opt to take that option...shame to 'destroy' something though Sad especially through a bad choice rather than use.
Wonder if they are worth anything to anyone? In all fairness though, if its soooo important that they aren't messed with, they could have devised a better way of permanently locking them in place....
213Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 2:13 am
It took me a full day of fiddling to get mine to where they are now.
Keep them they will be worth something to someone when we find the shafts are starting to wear in 2043.
214Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 2:20 am
floyd
floyd
RicK G wrote:Keep them they will be worth something to someone when we find the shafts are starting to wear in 2043.
 lol!
215Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 2:51 am
hmmm to long a bolt on the fairing tree that mounts to the steering stem ?
I wouldn't worry about it
216Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 3:51 am
floyd wrote:Ok, calling all experts....
Yeah, I was skeptical when I read what you had done.  Anyway, this thread has a PDF that may help you get those throttle bodies back into shape.
Also, read through this thread
217Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 6:04 am
floyd
floyd
Have you got the PDF mate? I cant find it on that first thread link
218Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 11:59 am
Robmac's second use of the phrase "this thread" is a gooden read it and follow it, mostly though if you have no intention of reshimming the valves any time soon then set your butterfly's anyway, then go set the bypass screws at the engines present state of tune, you will get the best sync for now, when you reshim or replace the rubber then redo the butterflies and the bypass screws after that and it will be at its best for then.
219Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 12:17 pm
floyd wrote:Have you got the PDF mate? I cant find it on that first thread link
You'll see the link hidden in the second post to that thread, at the bottom of the posting. It's not readily apparent at first glance.
220Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 12:39 pm
floyd
floyd
Can see the post in question....but no link...hmmm
221Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 1:10 pm
Rob you need to be logged in to get the link
222Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 1:17 pm
Ah, my computer logs in automatically for me so I'm oblivious to the need.  Sorry.
223Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 12, 2014 11:57 pm
floyd
floyd
Well, after a day spent away from 'Bob Marley and the Wailers' - and spent reading various things about throttle bodies, Ive decided Ill continue with what I have.
I will have to balance the butterflies as much as possible, mount up the TBs as usual and do a fair bit of fiddling once its all together and running to see if it can be synced well enough. If not, well Ebay here I come....
At least its a fairly cheap mistake, I just hate the waste though....
Anyways, whats the worst that can happen?
Poor runner, hard to start, vibes?
224Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sun Apr 13, 2014 12:31 am
floyd wrote:Anyways, whats the worst that can happen?
Detonation,,,,,,,blowback explosion..............and nuclear mayhem   :cherry: .
225Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sun Apr 13, 2014 12:45 am
floyd
floyd
Ooooooooh, Singularity - here we come!   affraid
226Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sun Apr 13, 2014 12:53 am
Around the World On a K100 - Page 5 44271
227Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sun Apr 13, 2014 12:54 am
Very Happy  Very Happy  Very Happy  You would get all three that you mention.....in the opposite direction, depending of how far out from the balance point you are.......and a higher fuel consumption.
228Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 1:14 am
floyd
floyd
Happy Easter Gents     Around the World On a K100 - Page 5 22936
Ok, on to business....Are these good enough to use again?
Around the World On a K100 - Page 5 P1050025
Around the World On a K100 - Page 5 P1050026
Around the World On a K100 - Page 5 P1050027
Around the World On a K100 - Page 5 P1050028
229Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 1:21 am
Although not the only measure of a good friction plate, what's the thickness of the material?  Spec says :
Total thickness of clutch plate (with lining) = 5.3mm ± 0.25
Min. thickness of clutch plate = 4.5mm
Yours doesn't look fouled by oil in any case.
230Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 1:40 am
floyd
floyd
robmack wrote:Although not the only measure of a good friction plate, what's the thickness of the material?  Spec says :
Unless Im mistaken, these are the 'pressure plate' and 'housing cover'.
I have a brand new friction plate to go in, just wondering about the little tiny bits of pitting and marking etc, or if this doesnt really matter.
I believe it was the original 220,000km - 30 year old friction plate in there, which was trashed by oil and was general rooted, but it wasnt worn right down to the point of the rivets scoring.
There are marks left by what looks like the rivets, probably while it was left sitting and those rivets corroded away and left a corrosion mark on the plate they were touching....?
231Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 1:52 am
Clymers lists the friction plate spec as 5.05mm - 5.55mm, minimum thickness 4.5mm.  This jives with the BMW spec I referenced.
If I had a brand new friction plate (or clutch assembly) and it was my bike, I'd not even think about the old one.  I'd just replace it as a matter of course.
232Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 1:57 am
floyd
floyd
yeah yeah yeah totally with you mate. I have a brand spanking new friction plate here to go in. The old one is in the bin. My questions has absolutely nothing to do with the friction plate.
I want to know about the acceptable wear on the items in the pictures - the pressure plate and the plate housing. Im already to put everything back together, including a new friction plate. Just need confirmation on the other items, as they were not as sparkly new as I was hoping Smile
233Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 2:58 am
The surfaces look OK to me. not by any means perfect but acceptable. Make sure they are flat i.e. not dished so that a new friction plate will only bite at the edge. When I put a new friction plate in my K1100 the steel plates were dished so bad that I had about 1/8" effective area at the outer edge and guess what, the thing would slip at any more than a slight twist of the wrist.
I did however put a pair of dished steel plates back into a K75 recently because the friction plate was worn to match and had heaps of meat left. That was 12 months and 20,000km ago and its still fine. I would expect another 60-80,000 from it.
234Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 3:27 am
floyd
floyd
RicK G wrote:The surfaces look OK to me. not by any means perfect but acceptable. Make sure they are flat i.e. not dished so that a new friction plate will only bite at the edge. When I put a new friction plate in my K1100 the steel plates were dished so bad that I had about 1/8" effective area at the outer edge and guess what, the thing would slip at any more than a slight twist of the wrist.
There is a slight sharp lip at the inner and outer edges. only a few mm wide and maybe <1mm raised... would a bit of wet and dry on a flat block be advisable or a no no?
235Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 3:44 am
That is most likely where the friction plate does not touch. check the new plate does not touch there either and all should be OK.
You should be able to check with the depth measurement on some verniers the depth of the lip but I doubt it would be near 1mm but if it is on both then the spring gets a bit weak as it does with a worn friction plate. If it is a mm or more replace them.
236Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 7:26 am
floyd
floyd
Ok, sweet.
Got the clutch in, gearbox on and mock mounted the frame. Goota figure out where all the spacers go for the engine mounts etc....
Thanks to Waz for the loan of a torque wrench big enough to do up the clutch nut.
Got he clutch all lined up using a permanent marker I found in the tool chest, and by putting the GB on and off a few times
YAY!  Laughing
Around the World On a K100 - Page 5 P1050029
Around the World On a K100 - Page 5 P1050030
237Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 7:43 am
Looking good Floyd,
I might have to pay you a visit and borrow Wazzaz torque wrench.
Hey Waz, can I borrow your torque wrench?
Are you putting the fairing back on?
too lazy to go back through the last 97 pages to find out.
Just an fyi, there is a piece of rubber goes over the air box to help deflect the heat.
Put it back on when you put the frame on (if that is the way you are going)
Part number 6
Around the World On a K100 - Page 5 8
238Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 7:45 am
floyd
floyd
Ahhh yeah thanks for that Rossko. Almost forgot.
Will be putting the RS front fairing back on, with the exception of the side/battery covers, and thats it at this stage.
239Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 7:51 am
So you are coming to Nindigully then Laughing
Have you got side covers?
240Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 9:39 am
Yeah looking good Floyd, I think you'll need a confined spaces ticket soon, as your work space isn't getting any bigger.
241Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 9:55 am
k-rider
k-rider
The bike is surrely starting to look like a bike again , about that. Rubber thing , is its purpose to lead the air out the side vents instead of under the sidecovers ? And does it work (sorry to crash the trhead floyd)
K-rider
242Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 10:05 am
floyd
floyd
RicK G wrote:So you are coming to Nindigully then Laughing
hehehe maybe maybe...
I should have a few sets of side covers. We'll wait and see if there is a pair without broken poking bits.
243Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 10:16 am
k-rider wrote:The bike is surrely starting to look like a bike again , about that. Rubber thing , is its purpose to lead the air out the side vents instead of under the sidecovers ? And does it work (sorry to crash the trhead floyd)
K-rider
It is supposed to do that and well it sort of works. The heat coming back on the riders legs is a continuing source of complaint.
244Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 10:34 am
Yes mate.
Last edited by Waz on Fri Apr 18, 2014 10:36 am; edited 1 time in total (Reason for editing : dumb rs)
245Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 11:25 am
floyd
floyd
Part number 6
Can you get (6) in with the frame on, or it must be put in before the frame?
246Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 11:57 am
A bit of stiff wire to skewer the rubber and some soapy water and drag it through.
247Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Fri Apr 18, 2014 12:37 pm
If you need to repair the side covers or any other plastic this stuff is good gear http://www.threewayworks.com.au/plastex-2
248Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 19, 2014 12:25 am
floyd
floyd
Ok there is alot of conflicting information on this topic, and Im a fool and didnt pay attention when I was dismantling....
When putting the frame back on a 1984 K100 RS, do you:
A) only shim the front left mount
B) shim all mounts if necessary
249Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 19, 2014 12:33 am
I'm assuming that your 84 has a bridge tank mount and not the plug tank mounts.  It could be either way (A or B) depending on how tightening screws 1, 2 and 3 reveal gaps at 4 and 5.
Around the World On a K100 - Page 5 K100rs%2520frame
This screen shot comes from the BMW manual, page 11-97.0.
250Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 19, 2014 12:37 am
floyd
floyd
Yeah Ive got that one mate and have seen it, cheers.
I think Haynes says something slightly different, like if there is any gap at any mount, its better to shim it then just pull it in with the bolts. This conflict has me seeking advise Smile
I have gaps at all mounting points...including 1,2 and 3 in that pic....
Do I follow the BMW manual, or shim each mount....hmmm...will go and play around a bit more...
251Back to top Go down   Around the World On a K100 - Page 5 Empty Re: Around the World On a K100 Sat Apr 19, 2014 12:44 am
RicK G wrote:If you need to repair the side covers or any other plastic this stuff is good gear http://www.threewayworks.com.au/plastex-2
I have both side covers and a major fairing mount fixed with good old 2 part araldite. They have both held for the 18 years I have had the bike.
View previous topic View next topic Back to top  Message [Page 5 of 18]
