Etch primer I used was shit and the paint never dried on it. I scrubbed it all off with kero and low and behold, the aluminium looks alot nicer then it did pre painting. So, bare the swing arm shall now be.
Got it fitted with new bearings, new rubber boot and a new circlip to hold the boot in (the bearing shop still like to give me free cir clips) and its now fitted to the gearbox. The swing arm pivot bolts cleaned up very nicely indeed. Only thing is - I forgot to lube the GB output shaft, so I will have to take it off again. Oh well, its easy as. Also, the pivot joint on the 1 drive shaft I have with decent splines is shot. Dont know why I didnt notice this before, but Im now driveshaftless. In need of a decent 16 tooth drive shaft people
Got my new K1100 centre/side stand assembly cleaned up and painted fresh.
Started cleaning up my only decent (spline wise) final drive. The rotor is 4.9mm which is over spec (according to clymer) and was covered in surface rust, but cleaned up ok and the local brake mechanic guy who I pester once a week (for his press) reckons its fine. One of the bolts which holds the rotor on has been sheered off and I will need an 'easy-out' to get it out. I have spare bolts here.
The seal at the pinion drive splines looks warped and deformed, but there was no evidence of an oil leak in my opinion. Just heaps of rust coloured shit flung every where.
I am literally in between jobs right now (just quit one - start the new one on Monday) so have shot out to the farm (compressor and spray gun here) to finish painting my tank, tail and RS nose fairing. Camo green - here we come!
The 14mm - 10mm bolt is in the post along with a 14mm tap set (tapered and butt?) care of the Uncles in Gladestone. Bloody legends.
Do you think I should tap the entire 35mm length of the engine mount on the block, or just tap down 25mm or so, so the sleeve butts up against something? I have no idea, just thought about it on the drive out here today.
Anyways, back to priming/painting and sorting through my parts depot
Anybody need any K100 parts while im here?
