551 Re: Around the World On a K100 Sun Jun 22, 2014 6:11 am
floyd
So, you know the water temp sensor? that simple little gizmo that is so simple its never meant to fail? Yeah, well 3 out of 4 of mine are cactus.
One of them did not have connectivity, another 2 were stuck at 5.5 k ohms, indicating freezing point, one seemed ok, but for some reason kept the FI thinking the engine was cold and therefore it ran rich when it was up to running temp.
(EDIT: the one that was causing the rich running + flooding was actually for a 16V. )
The 4th and final seems to be the keeper, as I now have idle, easy cold & hot start etc.
As you will see, the TB's are way out of wack, even though the PO reckons the butterfly adjustments have not been tampered with. Either way, the 3rd and 4th butteryflys were sliiiightly open when I installed them, indicating to me they have been adjusted or they have gone out of wack over time. Now they are very difficult to balance. I have shut the indle adjust screw thringys in all the way and held the throttle open a tad to observe the difference and it looked pretty much the same as it does in the video.
Will play more with the balance next week, but for now Im just totally stocked its running ok!!
Oh, I decided to measure the resistance of the ignition coils and leads. Leads were ok, but one coil gave a reading of 300ohms. I check my spare, ratty looking set and the appropriate replacement measured ok at 10 point something ohms which was the same as the other 'good' one. So from to shagged sets I made one ok one. If anyone is selling a set of the later model ones, please PM me. I have K1100 coils to sell as well.
More to come. Been a busy day.
