101 Re: Around the World On a K100 Sat Mar 15, 2014 6:47 pm
floyd
AL-58 wrote:In tribute to Bob Marley & the Wailers?
I think the beast just found its name
RicK G wrote:The LT had 2.91 ratio as did the RT but the RS has 2.82 and is interchangeable with the LT/RT
The bike is designed to run at those RPMs. It's not a Toyota Camry. It runs at even higher RPMs at Autobahn speeds.snowbeard wrote:so you guys are saying that the LT was already geared to have longer legs? I'm surprised, running 5K rpm at ~80 mph seemed like I could have really used a 6th gear!!
I always thought that these 100's would get pretty great mileage if they had another gear, 38mpg isn't that great overall.
So is this just the output shaft, or the entire gearbox? Could the K75's 3.2 be substituted for a K100? (not that I have the time or energy to do so, but as an idea)
Sorry to hijack your thread mate, looking forward to the next installment!
Ohh, a camry had a couple of those .duck wrote:The bike is designed to run at those RPMs. It's not a Toyota Camry. It runs at even higher RPMs at Autobahn speeds.snowbeard wrote:so you guys are saying that the LT was already geared to have longer legs? I'm surprised, running 5K rpm at ~80 mph seemed like I could have really used a 6th gear!!
I used to ride my K75RT around Montana at 7K+ all day long.
Inge K. wrote:15 x 2,5 mm and 27,3 x 2,4 mm.
True but it is much better than the nitrile which doesn't take a lot of doing.Inge K. wrote:Viton isn't that fond of hot water, the bigger o-ring is for a coolant passage.
I am really sorry to hear that i just used tve black ones after a outputshaft rebuild.RicK G wrote:Don't use the black nitrile O-rings they go hard and will leak within 2 years. Use the red silicone or the brown viton but red silicone is the best.
k-rider wrote:I am really sorry to hear that i just used tve black ones after a outputshaft rebuild.RicK G wrote:Don't use the black nitrile O-rings they go hard and will leak within 2 years. Use the red silicone or the brown viton but red silicone is the best.
.i thought they where fine since i bought them at motorworks.
well the bike is running , i guess ill just have to see for how long
k-rider
k-rider
charlie99 wrote:very informative inge ...thanks for the link
Ooh, thats a relief, thank you for postingInge K. wrote:k-rider wrote:I am really sorry to hear that i just used tve black ones after a outputshaft rebuild.RicK G wrote:Don't use the black nitrile O-rings they go hard and will leak within 2 years. Use the red silicone or the brown viton but red silicone is the best.
k-rider
It isn't necessarily that bad k-rider, on the motorworks page it's informed that this o-ring could be red or black.
I assume that both colours is of the same material and quality.....
Also have a look at this.
Similar topics
