Go to page : Previous  1 ... 6 ... 9, 10, 11 ... 14 ... 18  Next
View previous topic View next topic Go down  Message [Page 10 of 18]
451Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Thu May 22, 2014 3:06 pm
452Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Thu May 22, 2014 6:12 pm
floyd
floyd
A) Thanks all for the bash plate ideas. I will be using the crash bars so will figure out a way of using those mounts. Looks like in some of the above pics that the front of the guard is being held on by 2 oil pump cover bolts....
B) What is the likely hood of my ignition leads being cactus after 226,000kms? Is there a good way to test them, should I just order new ones from Realm (wish I did when I got the shock)
C) If any of you have a store run by a little Chinese or Vietnamese lady, that sells all manner of cheap, cheerful and sometimes nasty items. You know, the 2 dollor type shop. Go there before you to the hardware store.
SHe sells spray paint for $3.50 (which is great stuff) and she has an entire wall of tools and hardware. The other day I bought some bolts extractors (easy outs) from Mitre 10 (aussie hardware chain) and they were $30 for the set. At the Chinese shop - the exact same set - $3.00!!! I was nearly sick when I saw it...and its the same for nearly everything else. She has great stuff. Tiny needle files, tap and die set....all nasty, but for a single use requirement they are ideal!
453Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Thu May 22, 2014 11:13 pm
floyd
floyd
Around the World On a K100 - Page 10 P1050120
Hmmmm went down to the battery world shop and they had Deka batteries for a reasonable price so I bought one and a heavy duty negative lead.
The poor lady at the shop then proceeded to demonstrate how to connected it up, whereby she accidently connected the neg and pos to great excitement.....
I was nice enough to accept a $20 discount....but am now slightly regretting it....
454Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 23, 2014 4:26 am
floyd
floyd
Got the Heidenau tyres fitted today, front and rear. Look great!
Around the World On a K100 - Page 10 P1050121
On another note, the next hiccup has occurred....
I dont think that using the K1100 TB's and LT throttle cable will wirk with the LT handlebars Sad
Cable is not nearly long enough - even trying all different routing paths.....such a bummer.....
I guess my only options are to use different bars or get a custom cable made - as even reverting to stock K100 TB's wont work, as I am using a K1100 master cylinder...
DIY Cable kit
Custom Cables
455Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 23, 2014 4:42 am
they look verry different to what i had imagined floyd ...
nice one !...they might even have a chance at hanging on the tar pretty well
456Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 23, 2014 4:43 am
Have you got an RS throttle cable they are shorter by at least 100mm.  I have a K1100LT with all the usual bits and the positioning is the same and it has plenty of slack
457Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 23, 2014 4:47 am
floyd wrote:A) Thanks all for the bash plate ideas. I will be using the crash bars so will figure out a way of using those mounts. Looks like in some of the above pics that the front of the guard is being held on by 2 oil pump cover bolts....
yep dont discount the bad tolerence  and poor manufactured chineese crap for one offs ....floyd
just keep the location to yourself ,,,so you have a chance of getting what you need ...like tac puller pliers ...just right for those oceter clamps ...and under 5 bucks ...grin
keep at it mate !!!
458Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 23, 2014 4:50 am
floyd
floyd
charlie99 wrote:they look verry different to what i had imagined floyd ...
Yeah they are a bit more hardcore then I was originally planning....but i read alot of good reviews so we'll see how they go.
RicK GHave you got an RS throttle cable they are shorter by at least 100mm.  I have a K1100LT with all the usual bits and the positioning is the same and it has plenty of slack
I ordered the LT cable from motobins (motobins # 35470) but its seems about 150mm to short...
EDIT:
I have just ventured down the back garden, to where the mighty K stirs...head torch on head, beer in belly - to experiment - and, to my merriment, the cable has now chosen somewhat inexplicably to fit.
459Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 23, 2014 6:52 am
woohoo !
460Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 24, 2014 4:23 am
floyd
floyd
Ok, so im going to be starting the engine again for the first time since I tore the beast down....
Im concerned about any crap that may have fallen into areas that crap should have (im talking really small shit here, you know, dust etc)
Any methods/tips for this first start up? Should I run it for a little bit and change the oil?
461Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 24, 2014 5:28 am
Christ you ask a lot of questions to the forum, Just start it up (if it starts ) then bring it up to operating temperature and sync the throttle bodies .  Don't be to worried about gasket silicon, it wont get through the oil strainer and wont hurt the engine. If all is running well, the engine oil should be fine for the first 1000 Ks, but if your fussy, change the oil after about 200 Ks and give it a filter. Years ago you could buy running in oil for start up, then change for operating oil, but that's long gone.
462Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 24, 2014 5:37 am
There's a lil green button on the right handle bar. Don't rev the shit out of it like we used do with the police bikes when we started them but that was just till the oil pressure came up. Twisted Evil
Yer cud always chuck a corn sack under it ter catch the bits.
463Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 24, 2014 5:59 am
floyd
floyd
Thanks lads for your patience and wisdom.
464Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 24, 2014 6:01 am
smithy wrote:Christ you ask a lot of questions to the forum, Just start it up (if it starts ) then bring it up to operating temperature and sync the throttle bodies .  Don't be to worried about gasket silicon, it wont get through the oil strainer and wont hurt the engine. If all is running well, the engine oil should be fine for the first 1000 Ks, but if your fussy, change the oil after about 200 Ks and give it a filter. Years ago you could buy running in oil for start up, then change for operating oil, but that's long gone.
giggles  Around the World On a K100 - Page 10 44271
just do it floyd ...good luck
465Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 24, 2014 6:06 am
And video the process for our entertainment.
'93 K1100LT
Around the World On a K100 - Page 10 K-dogs10
466Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 24, 2014 6:17 am
Yeah , good luck with it mate, what could possibly go wrong! It's not a rocket, so rocket science doesn't come into it, you need to own a Triumph for that.
467Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 24, 2014 7:18 am
smithy wrote:, what could possibly go wrong!
Around the World On a K100 - Page 10 Bang10
Sorry, just couldn't leave it.....................good Luck, Floyd.
468Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 24, 2014 8:02 am
smithy wrote:Yeah , good luck with it mate, what could possibly go wrong! It's not a rocket, so rocket science doesn't come into it, you need to own a Triumph for that.
your doing well smithy ...  i appreciate it
giggles
469Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Mon May 26, 2014 8:24 am
Hey Floyd, once the fear & excitement of the start up subsides I'd really like to see a photo of the Heidenau on the front, especially the sidewall markings as you were saying the 110/80 x 18 was bi-directional.
470Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Mon May 26, 2014 8:56 am
Well come on Floyd did it go, don't keep us in suspense. bounce
471Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Mon May 26, 2014 10:00 am
There's a lot of smoke about, that might be a sign.
'93 K1100LT
472Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Mon May 26, 2014 5:44 pm
floyd
floyd
thanks for the overwhelming optimism....
not done yet. keep realising I have left parts at my various storage depotos. The hunt is currently on for my hall effect sensor cover (not sure if this effects starting or not)
The biggest set back since the week end and now is the fact that I stupidly cleaned up, and fitted seals to the WRONG bloody oil pump. So if anyone needs a nice K1100 oil/water pump housing with brand new seals fitted, let me know....
The positive side of that coin is the fact that my oil pump re build kit was in the box that went missing in the safe place. So I ordered a new one and then the safe place revealed its self. So I had a 2nd kit on hand....
Oh, and for the record - this does happen to be my build thread, so Ill ask all the damn questions I like Wink
Now for my next one. and this one may just take the cake.....where does the other end of the bloody Neg lead bolt onto to? The manual seems to have paid as little attention to it as I did while disassembling it.
(front Hiedenau pics coming up Gaz)
473Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Mon May 26, 2014 5:56 pm
floyd
floyd
Took this the day I got em. Will get you the side wall pic soon. The dealer told me that the distributor told him it was front/rear. I trust dealers to much - my father worked for Frasers - I should know better.
EDIT: I just went and checked - it does have rotation markings for front and rear mounting.
Around the World On a K100 - Page 10 P1050122
474Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Mon May 26, 2014 7:13 pm
Nice tyre.
Is the 1100 pump the same as the 100? Is it black? I need new seals.
Negative lead.
Around the World On a K100 - Page 10 Wp_00010
475Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Tue May 27, 2014 12:27 am
floyd
floyd
rosskko wrote:Nice tyre.
Negative lead.
Thanks Rossko,
The pumps are different. They changed the size of the gears wheels on the shafts, and the housing is machined differently to accommodate. I knew the shafts had changed, but did not realise the housings had changed too.
476Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Tue May 27, 2014 1:27 am
Thanks for the tyre photo Floyd. That's a serious looking front tyre.
I'll certainly be following your thoughts on how they perform when you get to ride them on a variety of surfaces. I'll get some dirt under the Pirelli Scorpion Trails on the way to the Alpine Rally. They have certainly been good on the bitumen for my riding.
477Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Tue May 27, 2014 1:34 am
floyd
floyd
Gaz80 wrote:Thanks for the tyre photo Floyd. That's a serious looking front tyre.
Yeah Im curious too. They are marketed as a true 50/50 tramac/gravel....Im fairly certain they will be a little to bias towards the dirt for me, but hey, ill give them a good thrashing prior to departing these fine shores and make my mind up. The dude at Balmain motorcycles reckoned they were the pic for what I was describing (vs the Scorpions) and some good reviews convinced me. But the proof will certainly be in the riding....Good to know there are dual sport tyre options out there though.
478Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Wed May 28, 2014 6:33 am
floyd
floyd
Around the World On a K100 - Page 10 B0000193
On most of my oil/water pumps, #16 is a threaded plug. On one or 2 of them though, its another sensor of some sort. Whats the sensor for?
479Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Wed May 28, 2014 6:35 am
k-rider
k-rider
Its for water temperature sensor
k-rider
480Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Wed May 28, 2014 7:33 am
It goes directly to an optional water temperature gauge.
481Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Thu May 29, 2014 4:27 am
floyd
floyd
Well....My clock works!
Nothing else seems to be though...yet...
482Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 5:57 am
floyd
floyd
The sun has gone down and the head torch battery has died so its that time of the day again....
Turning over. No start. Has spark. Not getting fuel.
483Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 6:10 am
Does the fuel pump run for ~1,5 sec after you have pushed the starter button?
Is Power present at fuse #6 when you push the starter button?
484Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 6:13 am
floyd
floyd
Inge K. wrote:Does the fuel pump run for ~1,5 sec after you have pushed the starter button?
No fuel pump action at all. (and it was working before I endeavoured on this voyage)
Dont have a multimeter. will have to pick one up.
Have also had to wire on another connector for the insturments, as a few cables are broken on my wiring loom...
 Just thinking out loud here, as excitement mixed with frustration has got the better of me...
If the fuel pump does not come on when the start is pushed, it can be:
- bad pump
- bad wiring/connectors
- bad fuel injection relay
Is that it? Can it also be potentially caused by bad computer\s?
485Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 6:29 am
floyd wrote: Dont have a multimeter. will have to pick one up.
Got a test lamp?
Around the World On a K100 - Page 10 Testli10
You need a functional fuel pump to fulfill post #467.
486Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 6:37 am
floyd
floyd
Got a test lamp?
No but I will tomorrow.
Burn baby Burn Wink
487Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 6:41 am
floyd wrote:Can it also be potentially caused by bad computer\s?
Yes, the relay got its signal from the ignition ECU.
It grounds the relay coil, the relay have constant power on the other side of
the coil.....when ignition and kill switch is on.
488Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 6:52 am
floyd dont use a test lamp ...please ...
get a reasonable multimeter ,,then we can all breath a sigh of relief
dont forget if you get a auto ranging multi meter you might have to wait for the scale to settle durring an intermittent event
always best to get one with a fixable scale   and learn where you should fix the scale to catch those events ...for most of us any reasonable multimeter should fix the scale at 20 volts (full range )? for dc voltage
and out here should be about $30 ....avoid going to motor shops to buy one you will pay more than needed ....maybe jaycar or similar
...psst ....dont forget the "deoxit" from them too
their needle file set (under 15) could come in handy for cleaning up some of those tricky connectors as well
489Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 7:13 pm
have you checked your earth points?
Around the World On a K100 - Page 10 10_x_110
490Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 7:33 pm
floyd
floyd
groverK wrote:have you checked your earth points?
Morning Gang....
oh the joys of facing a day of wiring - My least known subject....
WIll head off to grab a multimeter and some shrink wrap shortly.
EARTH POINTS: there is the brown wires under the tank, the neg lead to the gearbox, the rear left right engine mount (the manual says cover this join with grease when assembling) On an early K100 I think thats it?
It doesnt help much that I have 3 different harnesses here and there are differences in all of them, so making comparisons isnt that easy.
For example: on the loom i am using, there seems to be an extra lead going from the pos terminal directly to the fuel injection relay, and I cant find this on the other 2. I didnt have it connected last night, but when I reinstall the loom I will try with that lead connected up.
(I removed the loom last night [getting fast at it now] to deoxit every connector and rewrap it in front of the telly - seriously considering getting some fuel line quick disconnectors though....)
491Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 7:38 pm
492Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 8:12 pm
Have the fire extinguisher ready.
493Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 9:06 pm
offline???..............and we're all just sitting here and waiting for the fireworks.
494Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 9:09 pm
Havent seen any smoke pyres to the east yet.
'93 K1100LT
495Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 10:48 pm
floyd
floyd
AL-58 wrote:Havent seen any smoke pyres to the east yet.
Might have to come and pay you a visit Al....
Fuel pump is siezed....
can these be stripped down for a temp fix anyone know?
496Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Fri May 30, 2014 11:20 pm
floyd wrote:It doesnt help much that I have 3 different harnesses here and there are differences in all of them, so making comparisons isnt that easy.
That particular wire you're referencing is present in all K100 wiring harnesses from RT/RS pre-85 onwards.
IMMO you'll drive yourself crazy doing comparisons like that. Stick with the harness that appears to be the MOST intact and work from that point. Set your stake in the ground and work through any problems. A good schematic is your best friend.
497Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 31, 2014 12:11 am
a good suggestion rob ...
yes floyd some have done it
the real issue is doing it backup again ....there is the drive assembly for the rollers in the bottom of the pump which has no real way of locking off the mounting screws at the right tension required .....you would need to find some fuel proof locktight ??
many just go the cheep replacement version ...fords and such ....rick is a big advocate of that ...and a few locals bought new pumps for around the 40 mark
some times ebay is your friend
good luck
498Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 31, 2014 12:34 am
499Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 31, 2014 12:54 am
I bought the oem one from ebay for $40
You can have it for that if you want
500Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 31, 2014 1:57 am
I was luckier and got two for 35 each, but Floyds just picked my spare new one(it was already his, we just hadn't done the exchange yet). With luck he'll have it running tonight.
'93 K1100LT
501Back to top Go down   Around the World On a K100 - Page 10 Empty Re: Around the World On a K100 Sat May 31, 2014 4:18 am
floyd
floyd
update:
New fuel pump fitted. Working great, fuel pump runs when starter pushed, fuel running back into tank.
But no kaboom yet.
Still have spark, but it seems to me that no fuel is getting into the cylinders....
I followed the troubleshooting flow chart in downloads right to the end, tested pin 9 and 12 on the black box. got a blinking light on the multi meter when I hit the starter. hmmmmm
View previous topic View next topic Back to top  Message [Page 10 of 18]
