151 Re: Big Block K100 Tue Mar 22, 2016 11:35 pm
Lookin' good TWB, but you've gotta get rid of those chicken strips!
Yeah, it's true, in time that'll happen. For a bike that's travelled barely 300 or 400 discrete metres round my neighbourhood I'd say the tyres are doin' alright!robmack wrote:Lookin' good TWB, but you've gotta get rid of those chicken strips!
Def. It's deeper, more resonant, a bit too loud when on the boil, actually, but it goes away out on the road. Speaking of on the road. Sorted the lights out. They work a charm. Check this sequence.K75cster wrote:Flash work TWB, it does sound like a K but its um tuned or tighter in sound and there is that rumpety rump sound in there, its got a deep idle hey.
Motorbike Mike wrote:Looking better with the longer silencer, I'm not a fan of shorty silencers, they just look wrong.
How's cooling on the older K radiator?
How about in front of the water/oil pump like mine?Two Wheels Better wrote:Motorbike Mike wrote:Looking better with the longer silencer, I'm not a fan of shorty silencers, they just look wrong.
Three row rad with a 6-1/2" SPAL fan, no worries. Still fiddling with possible rear located oil cooler and 4" fan...
Longer, tri-oval can is better in all ways. Cheap, at $154.95 delivered, too. Look at delkevic USA . com
The issue with that particular oil cooler is that it loads the water cooled side with more heat and as the K's cooling system is only just adequate, I think that would be a bad move.
Barely adequate I think I wroteTwo Wheels Better wrote:True Dai. I have never thought of my various K bikes as having inadequate cooling with that big old fan and even the two row rad.
riddle the sphinx wrote:Where are you tapping into the oil circuit for the cooler?
Have a read about my Flying Brick to see how that's done.riddle the sphinx wrote:Aye, I forgot we're dealing with the 1200 engine here. Theoretically if you wanted to install one on the 100 is there a good point to tap in? I know you get a in line attachment to go on the oil filter but this wont fit where the filter on the 100 is,
is it me or does it look like two surgeons with tweezers fighting a martial arts weapon in the middle of the engine?!
I was under the impression that a K1100 ran at 3bar but according to our resident guru IngeK they run at 2.5 bar.Two Wheels Better wrote: A stock K100 is 2.5 bar or 36 psi. A K1100 runs 3.0 bar or 43 psi. A stock K1200RS/GT runs 3.5 bar or 50 psi, and the hotrod Hexhead R1200S-Sport delivers 4.0 bar or 58 psi.
I'll keep it at a more sedate 60 for the time being.
robmack wrote:Talk about deja vu, TWB. I visited Larry at SpecialKs this past summer and we worked together on his Beast which was acting up with backfiring and poor idling. He did the same swap as you - adjustable aftermarket FPR with a swap from round to square section fuel rail. Same clip problem, same failure. He adjusted the FPR to 2.5 bar if I remember correctly, and swapped the injectors which eventually cured the problem (I presume the failing injectors needed cleaning).
Onya Dazza..... Great stuff!Two Wheels Better wrote:Tonight is Grit City Moto Night and I'm gunna ride the Big Block.
Kai Ju wrote:Just read the whole thread, kudos on building a really nice K hybrid.
But what caught my eye is your intent to run the Vapor.
I've had one on my plated XR650R since they came out and really like all the features it offers.
So I was planning on using the Vapor on my project K.
I've been scouring this Forum for days now and found the info on the resistor to make the charging system work as well as using an R1100 neutral switch for getting the neutral light sorted out.
So, have you installed yours yet ? If so, how is it working for you ?
Any tips would be appreciated, I wish I could reciprocate but I haven't even ordered mine yet.
Last edited by Two Wheels Better on Wed Jun 22, 2016 10:41 pm; edited 1 time in total
Similar topics
