1Back to top Go down   K100 cafe racer & scrambler combo! Empty K100 cafe racer & scrambler combo! Tue Dec 24, 2013 10:46 am
simosvog
simosvog
The design is complete, the rear frame will be raised and the piassenger seat will have a removable cover. Off we go to BMW MAN(iatakos!) http://caferacercult.gr/editorial/motor-b-m-w-maniatakos.htmlK100 cafe racer & scrambler combo! 993502_647697495272280_907325074_n
http://www.motorinn.gr
2Back to top Go down   K100 cafe racer & scrambler combo! Empty 16V block with 8V head Fri Dec 27, 2013 10:15 am
simosvog
simosvog
Hi,
My engine broke down and the crankshaft and bores are damaged, I found a very good engine block complete with pistons from a 16V engine that had only 15TK, does anyone know if the pistons are the same with the 8valve engine? will it be a straightforward swap?
Any ideas wellcome, thanks
Simos
3Back to top Go down   K100 cafe racer & scrambler combo! Empty Re: K100 cafe racer & scrambler combo! Fri Dec 27, 2013 10:51 am
Ghost who rides
Ghost who rides
Just swap the engine Simos don't try to mix and match
You must tell us how the crank and bores got damaged? Oil?
4Back to top Go down   K100 cafe racer & scrambler combo! Empty damaged engine Fri Dec 27, 2013 11:10 am
simosvog
simosvog
I bought the bike secondhand and after riding for about 500 klms the bike started to make a knocking noise when warm, I drove it to a friends garage and borrowed a oil pressure gauge, it read 25 psi at idle and 40 psi at higher rpm so I thought it would be ok to drive home but by the time I got back everything was @#$%^@ up! When I opened the crankcase the crank is moving like there are no bearings and still the oil pressure light did not come on!!???
5Back to top Go down   K100 cafe racer & scrambler combo! Empty Re: K100 cafe racer & scrambler combo! Fri Dec 27, 2013 11:49 am
Ghost who rides
Ghost who rides
Got me stumped (sorry POMS)  bears with better brains will Know.
Very unusual is my only comment, got to be an anomaly at worst?
I have been on this site for a couple of years and bottom end?
New to me, chime in guys.
6Back to top Go down   K100 cafe racer & scrambler combo! Empty bottom end Fri Dec 27, 2013 2:41 pm
simosvog
simosvog
From what I hear these engines dont break but this one did! The bike was not being used since 2008 maybe a blocked oil passage? that makes sence since even with the bottom end completely ruined the oil light wouldnt come on K100 cafe racer & scrambler combo! 259495
70psi is the correct pressure for a K.  40psi would tell me there is a problem and it seems that your bottom end was well worn or damaged already.
The oil pressure light will not light at 40psi the pressure probably would need to fall below 20psi for that to happen.
There is no substitute for a good oil pressure guage
16v pistons are not compatible with an 8v head you will bend your valves as the cutaways are not in the correct place. As Ghost said a complete used engine will be the cheapest alternative.
8Back to top Go down   K100 cafe racer & scrambler combo! Empty looking for used engine Sat Dec 28, 2013 1:44 am
simosvog
simosvog
I found out that the 4v has a higher compression ratio and that the valve cutouts dont match, so I am on the look for a new (used) engine. There don't seem to be any availiable here in Greece so I'll have to get one from e-bay. I am not that crazy about the idea because I cannot check the engine before I buy and it's 120 euros for the transportation from Germany so if it turns out to be in bad shape I'm stuck with it. Does anyone know of a trusted source for used parts in Germany?
Dazco
Dazco
How about trying motoworks in the uk , they might be able to help.
Daz
