1 Engine block wear Sun May 15, 2011 5:04 pm
shay
Hi
My 1989 k100 doesn't run!
It has 160000 k's on the meter but it wasn't working when i bought the bike and i fixed it so i can't say if it is close to the real number of kilometers that the bike actually did.
All the tests i did brought me to a conclusion that the engine block is worn and low compression causes the engine to stop.cylinders 1,2,3 show 150 psi & cylinder 4 show 130 psi.
It does fire up after i pour some engine oil into the cylinders through the plug holes but after reving for a few minutes it burns the oil and dies again.
After asking for the advise of a local autorized workshop;i was told that this is a well known problem which happens in some of the k's and since the cylinders are covered with nicksil (mind my spelling),re-borring is not an option.
it appears that the only option i have is to either renew the piston rings (a short term solution)or to change the engin block which is not an option for me since it means that i will need to buy another bike and to make one from two but this bikes are rare and expensive where i live.
so i decided that i will open the engine and check the block for wear but before i order the rings and the gasket set i thought i should try to look for a good advise in the forum-
Did any one encountered this problem and solved it in a way which wasn't changing the block?
Shay
Shay
