1 quick question ....bevel drive output shaft seal Fri May 20, 2011 1:27 pm
hi guys justa quick one .
i installed the replacement bevel drive a couple of weeks ago but have had a leak from there .
i initially thought it was a output shaft seal and bought one to replace it with .....after dissasembly i found the screws for the halves of the drive were in fact loose ...which i tightened and replaced the seal anyhow .
i still have a leak but its now from the seal which i replaced ......
does it take some little while (killometers) for the seal to take up ? as ive only done about 50 or so over the last couple of weeks
i have linished the shaft so that it would "bed in" in a rotary fashion ...around the circumfrence of the shaft ....(ouchy ouchy skin off knuckles )
and the leak is now only a drip or so ...but always wet at the bottom of the drive .
seeing that tommorrow we have this planned ride ....do i replace it with a new one and take more care in installing it ?
or should i let it bed in some more ??
