1 JJ Cobas K100R Flying Brick Tue Mar 10, 2015 5:55 pm
Motorbike Mike
Here's Senor Cobas stood with his Flying Brick and this is the look I'm aiming for.
In the spirit of JJ's bike,it's an 8 valver.
The bike has to be quick and the engine has undergone a succession of modifications that include;
High compression pistons.
Ported cylinder head.
Modified combustion chambers.
Race cams.
Balanced con rods.
Lightened and balanced crank.
Straight cut primary gears
12;1 (ish) compression ratio.
16 valve Motronic EFI.
Larger throttle bodies.
38mm header pipes.
Modified oil /water pump.......and the list goes on!
Here is the frame and wheels just back from the Powder Coaters
That's about up to date now.
There's also the handling department but that's for another time!
Race cams.
Balanced con rods.
38mm header pipes.
