Today was a good day. I spent it in the garage....well, half spilt out into the driveway as it was only 25c and sunny - not as hot as it's been round here lately.
I knew it was gunna take some time, and was putting off the inevitable, but I went at the bar end indicators. The Pro Taper 'bars are 14mm ID and the K&S LED indicators are about 16.5mm OD. It's not a good fit. So out came the drill for a centre hole to feed the wires through then the heavy duty Dremel-like impliment was put into action to grind away the aluminium insides of the 'bars. I have wanted a tidy look without the clutter of indicators round the headlight or mounted to the forks. It took ages but worked.
Next up was the cooling fan. As I've used those four massive 44mm intake sleeves to mount the 38mm throttle bodies onto I had to sacrifice clearance for the OEM radiator cooling fan motor. I turned to the cheap and plentiful source - eBay - and obtained a 7" reversible, slim, shrouded fan and motor. Bloody hell if it too won't clear. I looked at mounting it to the front of the radiator and reversing the direction of rotation...what an incongruous lump of a thing sitting up there all exposed. Nuh, it's getting hidden away like God intended, at the back. I'll nip and tuck the shroud to make it clear the 'gooseneck' and hoses.
The other thing was the seat. I've not wanted to use anything like an original seat shape or seat pan. I like the shape and profile of the original BMW F800S/ST seat. I have attempted fibreglas, aftermarket seats from a Ducati, was even offered carbon fibre as an option, but they all come up short. I twigged to the idea of using a polyethylene cutting board - off-gas for the arse!?
I found a professional restaurant supplier down the street and bought a 24" x 30" piece in white, a 1/2" thick, and went to work with a black magic marker and a fine-toothed jigsaw. Once I'd got the rough outline, following the contours of the rear frame as it drops then rises to straighten out towards the back end, I clamped it into place with six carpenter's clamps and pointed the heat gun at it for a spell. Lo and behold it drooped and sagged (eventually, and with some force) and is now more or less following the intended bend.
The local marine upholsterer will contour and sculpt a bit of hard seat foam for me then whack a non-slip cover over it, rivet it down and we'll hope that it looks motorbikish enough.
At the mo' the bike is in parts and pieces again. I had wanted to have it ready for the annual (and top secret, ssshh) Isle of Vashon VME gathering this coming weekend. Ain't gunna happen, lest I wanna perch on a slab of plastic and keep moving lest it overheat....but at least I've got indicators, and a cutting board on which to cut the olives for my martini as I await the towie.
