Will be adding a nitrous oxide kit once its finished
Wizards of NOS SB75 4 cylinder direct port bike nitrous Kit
The unique concept behind the
Street-Blaster 75 makes it the simplest yet most effective direct port
system on the market and it is specifically designed for all 4 cylinder
motorcycles with or without the original air box fitted. The
distinctive feature of a Street-Blaster 75 system is the compact Venom
injectors, which are much easier to fit than US Fogger ‘type’ nozzles.
Venom’s can be fitted in numerous locations whereas Fogger type nozzles
are only suitable for being fitted into the head ports, which usually
requires the head to be removed for machining and is therefore more
expensive.Independent results have proven that when adding up to 75bhp, a
Street-Blaster 75 can out perform any other direct port kit in all
respects, whilst also being
more user friendly.No other system has such a desirable combination of low price, ease of fitting, user friendliness and superior performance
. Despite
the low price, this system still benefits from the same list of unique
high standard features as our Street-Blaster 150Bi. The Street-Blaster
75 has been designed to fit a stock street bike without any major
modifications and as a result can often be fitted without removing more
than the fuel tank, in less than half the time of other kits.
The
WON team have put a great deal of thought into the ease of fitting,
performance and cost when developing this unique system, to make sure it
ticks all the right boxes, for you and your bike.
If you’re looking
for up to an extra 75 hp, why search further, only to find a more
difficult to fit, more expensive and less effective system, when you’ve
already found the best?
from here:
http://www.noswizard.com/bike-nitrous-kits-2/street-bike-nitrous-kits/sb75-direct-port-bike-nitrous-kit.html
