1Back to top Go down   Reanimating an 85 K100RS Empty Reanimating an 85 K100RS Wed Sep 24, 2014 4:05 pm
VashonK100
VashonK100
I'm relatively new to motorcycles, I've been riding about 3 years now but I've been riding just about every day since I got the first bike, a 1979 BMW R65, still my everyday rider.
Recently someone offered me an 85 BMW K100RS for free.  I jumped at the opportunity and picked it up immediately.  He said it had an intermittent starting issue and just stopped riding it, it's been sitting ever since.  I got the impression that he was talking about 2- years.  It wasn't until I got it back to my place and had a closer look, that the reality of my situation settled in.  This thing was in bad shape!  And the tabs were from 1999!  It had been sitting for 14 years, and much of it outside.
So here I am doing what I can to get it back on the road and learning quite a bit along the way.
I started a blog but I've quickly realized I should be posting here, where I can take advantage of the tremendous knowledge base and generous forum members.
Reanimating an 85 K100RS Photo-10
Amazingly I was able to get it started with a friend over the weekend after pouring out the old gas (if you want to call it that) throwing in some seafoam and ethanol-free fuel, changing the oil, and hooking up a new battery.  It didn't purr like a kitten but it gave me faith that it was worth trying to bring back to life.
Reanimating an 85 K100RS 15336210
Reanimating an 85 K100RS 15150010
Reanimating an 85 K100RS 15336510
I decided that although I was really looking forward to having a bike with a fairing, it was going to have to go into the barn and wait to be restored at a later date.
The paint on the tank was stained from probably being on its side for a while, who knows.  I figured, it's an aluminum tank, lets just sand it down and see what it looks like.
Sanded down with a clear coat and new emblem:
Reanimating an 85 K100RS 15336211
Oh, and the tank had pinholes in it of course.  I opened them up a bit, used some JB Weld and then used Red Kote inside.
I'm on a pretty tight budget for this one, the original challenge was to keep it under $1K.  So any painting would be rattle can, I was going to go for black but found some silver metallic in the garage my son had been using and figured what the hell, let's see how it looks.  I was surprised how well it matched the aluminum.
Reanimating an 85 K100RS 15336212
Added a black stripe down the front fender and the back seat cowl for the hell of it.
Also added a British-style H4 Headlight and some torpedo turn signals, both from Dime City Cycles.  Some Bar end mirrors and a hell of a lot of scrubbing.
Put Progressive springs in the front.
Got a replacement rear shock from a friend off another 85 K100.
Updated the throttle cable
Just replaced all the plugs and wires.  It starts nicely and sometimes holds idle.
Challenges I'm facing now:
 - Tach and Speedo don't work (I took apart the cluster and checked connections all of which looked surprisingly good.
-  Neutral light comes on when starting the bike but then goes off.
-  Pipes have some rust holes.  Try and weld them?  Or replace (I'm on a budget!  And I know a welder...)
-  Rear brake cylinder is frozen up.  I'm still trying to get it apart but it's looking like it may need to be replaced.
-  throttle tube gears are bad, needs to be replaced
-  brake lights don't work
I guess that's about it for now.  It's been a hell of a lot of work for me to get it to where it is now.  I'm no mechanic so things probably took me a lot longer than they should have, but have learned a hell of a lot and spent a lot of time cursing in the garage.  I've got a lot of respect for these guys who do complete tear downs as winter projects (but I also have to question their sanity).
Any troubleshooting ideas or suggestions would be would be helpful.  Thanks!
http://www.strangelife.com
2Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Wed Sep 24, 2014 5:52 pm
You have done well so far. A lot of work but you will enjoy the end result.
Electrical connections need to be checked out. Sometimes this can be the problem and not the items that appear to not work. The earths, particularly under the gas tank are very important to clean up and reset.
Seems though the brake light switches themselves can give up. My rear became erratic and then stopped. If you get the rev counter going then you can use that as a speedo, 4000rpm equal 100kmh or 60mph.
Check the age of the tyres too, but if they were also 1999 or earlier you definitely need new no matter what tread is on them. They go hard and will be lethal.
Clean up and polish the fork stanchions until they are nice and smooth, any rust lumps will soon zap your fork seals. Change oil in them too. Without a fairing its a bit easier and there are posts about using a big syringe to refill them. Good advice!
The speedo sensor is on top of the final drive, very near the bottom of the rear shock. An Allen bolt holds in in and it will wriggle out with not too much force, just an O ring on it. It can be cleaned up. There is a connector from it to the loom at the front of the right hand side panel. There is another connector beside that which is the rear brake switch. Both connections should be checked. If you are trying to get the rear brake switch off use some WD40 first. Also take out the fuses and clean or preferably replace them.
There are some good posts on the instrument cluster, but first let us know what lights etc are working on them: as the speedo and rev counter problem might not be in the cluster itself.  Cluster internal light? High beam? Brake light warning? Turn signal? Orange and red fuel levels? Oil? Electrical charging? Gear indicator? Time? Pop up the chassis number because there were changes in 1985. Your seat and twin fuel level indicators suggest its the earlier 85 model.
Your handlebar switches may have a little internal corrosion due to sitting around. Might be a good idea to fit a headlight relay to reduce the risk of internal burnout of the left one.
Keep the posts coming.
Last edited by 92KK K100LT 193214 on Thu Sep 25, 2014 12:50 am; edited 1 time in total (Reason for editing : Typos by the dozen.)
3Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Wed Sep 24, 2014 6:00 pm
doing well so far .....keep it going, if and when you can
great to see another forgotten k returning to the road
sounds like you have some relay and fuse- fuse holder issues as well
look for some "deoxit "  we find it really helps all those wiring connector corrosion points
4Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Wed Sep 24, 2014 7:24 pm
Mossy1200
Mossy1200
That's 2 free K100s I have heard about in the last 2 weeks.
Im beginning to think I paid to much for mine.
5Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Wed Sep 24, 2014 7:44 pm
Good job, well done Smile
Reanimating an 85 K100RS Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
6Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Thu Sep 25, 2014 12:07 am
AJ.Valente
AJ.Valente
Wow, that's weird. Someone took an RS and turned it into a modified LT. Never seen that trick before. Shocked
But, yea, I agree it would be a great resto with just 40K on the clock. Look for a set of tuned headers. Most '85s have the Euro cam, and the performance boost with headers will turn it into a "screamer."
I'd also ditch the center stand for the K1100 type along with '86 style footpegs. It's an easy upgrade that makes the bike look better and the improved center stand won't rust out (you're going to have to replace it at some point anyway given its condition). See the pictures linked in my signature for an example.
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
7Back to top Go down   Reanimating an 85 K100RS Empty Global support! and bike info Thu Sep 25, 2014 3:17 am
VashonK100
VashonK100
Thank you all for the great feedback!  My todo list just got longer.
I'm also amazed at the global community with people living in all the places I'd love to ride some day!
Here's some more info on the bike:
Reanimating an 85 K100RS Screen10
8Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Thu Sep 25, 2014 3:55 am
VashonK100
VashonK100
Just ordered some Deoxit and will see if I can post a video that shows the series of lights that go on when I start the bike...
9Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Thu Sep 25, 2014 3:58 am
Kyle10
Kyle10
Sitting dormant for 14 years, outside no less. New battery, oil, gas and she starts.
This surely hints at core reasons for the many dedicated to K's. Awesome.
1985 K100rt 0052183
1983 Honda VF750 007713
10Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Thu Sep 25, 2014 4:43 am
Says it all!.
11Back to top Go down   Reanimating an 85 K100RS Empty rusty pipes Thu Sep 25, 2014 4:49 am
VashonK100
VashonK100
Current state of my pipes:
Reanimating an 85 K100RS Img_0811
Reanimating an 85 K100RS Img_0812
Salvageable?  It sounds like a Harley.
12Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Thu Sep 25, 2014 5:29 am
Kyle10
Kyle10
Reanimating an 85 K100RS Pipe_zps474ac69e
Possibly non-salvageable
1985 K100rt 0052183
13Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Thu Sep 25, 2014 7:34 am
VashonK100
VashonK100
Kyle, if I could find 4 of those I may be able to achieve the kind of torque I'm looking for...
14Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Thu Sep 25, 2014 8:32 am
hmm looks as though those pipes are after market or later series grafted in .
you can tell by the extra length loop- length  of number 4 pipe ...(but on the right path anyhow )  perhaps something like a supertrapp ?
I suspect that the baffling material is probably all gone (many had some form of fibreglass wrap for muffling the noise around an output core ...and some were taken out on purpose )
I would predict that once some backpressure is added you may find some more torque comes with it , without doing some intake breathing modifications .
clean them up and keep them is my suggestion , but perhaps try and find their origin and correct parts to repair the baffling
or sell them to me ? giggles
15Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Thu Sep 25, 2014 9:01 am
Kyle10
Kyle10
Those are definitely aftermarket/custom headers.
Do I see this correctly that there are actual holes in the pipes?
1985 K100rt 0052183
16Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Thu Sep 25, 2014 10:04 am
VashonK100
VashonK100
Actual holes indeed.  A few of them.
Reanimating an 85 K100RS Fullsi10
Reanimating an 85 K100RS Img_0813
17Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Thu Sep 25, 2014 6:38 pm
lol   evidence of an "off event" me thinks
patch em up and ride well ...giggles
18Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Fri Sep 26, 2014 4:01 pm
VashonK100
VashonK100
Charlie99 wrote:clean them up and keep them is my suggestion , but perhaps try and find their origin and correct parts to repair the baffling
I've been poking around trying to figure out what they are, no luck yet.
I'm going to try and get them off in the next couple days to have a closer look, clean them up and take them over to a welder friend.   I'd love to patch them up and maybe even wrap them.  We'll see.
19Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Sat Sep 27, 2014 12:42 am
AJ.Valente
AJ.Valente
The tubes are steel only, and susceptible to rusting from the inside out or vice versa. An experienced welder could make a duplicate. FYI, avoid short trips with these exhausts as moisture build-up ruins them. :suspect:
The Supertrap web site has replacement cores and baffles. A complete replacement muffler is also available, but still have to weld on the mounting tab.
If you'd like an OEM stainless steel muffler and pipes I have an extra set, asking $100 plus shipping (~$30).
20Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Sat Sep 27, 2014 3:26 am
VashonK100
VashonK100
I may take you up on that.  First I'm going to have a closer took at what I'm dealing with.  Trying to get them off this week.
21Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Sat Sep 27, 2014 5:31 am
Kyle10
Kyle10
I tend to agree here. To me it looks like rust from standing water, not so much an 'event.'
If you are interested in going the route of having a competent welder/fabricator duplicate your headers, let me know. We could split costs to have him make two sets. Looks like we're both WA denizens.
Working on fairings now. Hopefully a little inspiration for you (matte, as it's between coats):
Reanimating an 85 K100RS Frontfairing_zpseacb1695Reanimating an 85 K100RS K100PAINTtank2_zpsd934f82dReanimating an 85 K100RS Tail1_zps9024f24f
1985 K100rt 0052183
22Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Sat Sep 27, 2014 8:52 am
Mossy1200
Mossy1200
Nice work.
A guy in NZ has a set of restored race headers.
I might try borrow them from him and have some made.
Reanimating an 85 K100RS Muffle10
23Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Sat Sep 27, 2014 8:53 am
Kyle10
Kyle10
I'd buy if it doesn't mean a mortgage re-fi. Seriously.
1985 K100rt 0052183
24Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Tue Sep 30, 2014 2:27 pm
VashonK100
VashonK100
Kyle10 wrote:If you are interested in going the route of having a competent welder/fabricator duplicate your headers, let me know. We could split costs to have him make two sets. Looks like we're both WA denizens.
How much do you think it would cost to fabricate?  Imagining that's not cheap.
My welder friend is recommending new headers.
Fairings looking good!  You're more patient than me.  I only have so much time before family is dragging me from the garage.  The weather is starting to change and I'm already regretting choosing bar-end mirrors over heated grips (has anyone been able to do both?)... Going to try and bring my fairing back to life over the winter.  Maybe.  It's in pretty bad shape.
25Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Tue Sep 30, 2014 4:17 pm
VashonK100
VashonK100
I'm pretty sure these are the headers I've got.  I'm guessing they are the Luftmeister ceramic coated 4-1
Reanimating an 85 K100RS Screen11
If only mine were in as good shape. Sad
26Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Wed Oct 01, 2014 3:10 am
Kyle10
Kyle10
A good muffler shop would quote you ballpark if you took it with you to their shop.
Work continues... Very Happy
Reanimating an 85 K100RS Frontfairing2_zpsbabb057cReanimating an 85 K100RS K100PAINTtank4_zps3a1445e9
1985 K100rt 0052183
27Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Wed Oct 01, 2014 4:00 am
VashonK100
VashonK100
Paint is looking good!  What are you using?  I'm guessing its not a rattle can job?
28Back to top Go down   Reanimating an 85 K100RS Empty Re: Reanimating an 85 K100RS Wed Oct 01, 2014 4:41 am
Kyle10
Kyle10
House of Kolor:
- Body: Shimrin Solid Kolor Black
- Stripe: Hok Ice Pearl White
- Coat: Shimrin2 USC01 Kosmic Urethane Show Klear
Yeah, having a pro shoot 'em.
Seeing how good it's turning out has me looking down the rabbit hole, namely stripping the bike down to the frame for a powercoating. And if I do that, well I'll just have to upgrade the lights and finish the custom exhaust and and...
1985 K100rt 0052183
