Number of posts : 7967
I have an 84RT and a 92LT and have swapped a few parts between them.
For the most part as far as I can see the entire of the fairing and its brackets are identical so if you can get your hands on a complete fairing, storage boxes, storage box frames, storage box lids, leg panels, interior baffles, spider bracket and the and all the bits that go with it you are a lot of the way there.
Chances are you will buy a new screen as most used ones are not great.
If you are lucky it will have the indicators/turn signals and headlight in it. If not you will need them.
If you have the flat or RS bars, you will be looking for new RT/LT handlebars, RT/LT cables and the brake pipe from the front master cylinder to the splitter. I changed my bars and ordered a used one, when it came it was for the LT heated grips. The bars are different at the grip ends but you simply cut the lugs off if you don't use heated grips. If you plan on fitting the BMW ones make sure you get the bars for them.
You may also need the impact pad for the switches and ignition mounting.
The handlebar switchgear does not change but you will have to wriggle the wiring a bit to get the extra length. Check no loose connections before you put the tank back!!
Battery/side panels changed at some point too and I don't think are interchangeable, important to know the exact model so a photo is important.
A little hint too, if you don't know the state of the head bearings its worth doing them before you fit the fairing as its just easier to get at everything.
While you have the tank off change the fuel hoses and also the vacuum pipe and crankcase breather pipe....small money but easy to do at this time.
1971 Yamaha 125 YAS-1
