K1100 not starting Fri Jul 19, 2024 12:53 pm
fnikcs
![fnikcs](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![New member New member](https://2img.net/i/itest/ranks/default/default1.gif)
Hello everyone, I'm new in this forum and new bike owner.
Last year I bought a K1100RS 1990 and it burned down. I found a broken from K100LT 1989 and replaced everything. Little did I know that it was different, my K1100 had an oxygen sensor and the K100LT had MAF. After i fitted everything together my bike will start on cold and after I turn it off it wont start unless i let it sit for 30/40 min, and when I crank it will smell of fuel. I searched on forums and based on the suggestions I've replaced/refurbished follow components.
New: Spark plugs, fuel pump, fuel lines, fuel filter, water temperature sensor, Hall sensor, ignition coils.
Refurbished: fuel injectors.
Replaced from my friends K100RS 1984 the ECU (grey box) and MAF and still the same problem, Also at my MAF I tried to turn the gear clock-wise to make it run leaner. So far nothing has fixed the problem.
Valve clearance is as following (it's 16 valve):
Top: 0.15|0.15, 0.15|0.15, 0.15|0.15, 0.15|0.15
Bottom: 0.30|0.30, 0.30|0.30, 0.20|0.20, 0.30|0.30,
I've also placed an order for the pressure regulator which is supposed to arrive in a couple of weeks.
