1 Lack of power above 3500RPM... Fri Jul 12, 2024 10:53 pm
HZolio
Hi there!
So, i need your help!
The bike is my 1992 K100RS 16V, with 152000km. Starts, idles and rides flawless, but (more noticeable on 5th gear), it doesn't make more than 3500rpm easily... she can rise downhill, but at a cost!
I already adjusted CO and ignition, balanced those ITB, new plugs and "usable" plug wires. ALL fluids changed, refrigeration gremlins sorted, and air filter is new! Also changed the shot steering bearings and serviced the forks, new seals on the front brake pump, flushed all the DOT4 (ABS fully working ), all of this is obviously not the culprit but FYI...
On 2 months reading the forum i learned: the tank is mirror clean, the fuel filter (IDK) looks new, as the pump also!
I noticed, when adjusting the CO, the potentiometer was VERY sensitive. It is normal?
Where do i start? New fuel filter? Or...
Any help would be appreciated!
May thanks
May thanks
HZolio
'92 K100RS 16V
'86 R65
'10 R1200GSA
...and too many to list...
