1 push / bump starting - not jump starting Yesterday at 6:59 am
tinyspuds
Housebound and working thru my K do list.
Am I right in thinking that in order to push start my 85 8 valve K100 I should:
Put it in gear (2 or 3)
Short the clutch switch (ideally with a switch, or just the old fashioned way)
Hold down the starter button (to run the fuel pump run)
Can be done with a low (non-starting) battery but not with a completely dead one (fuel pump)
This process would be different on the 16 valve because of the way the fuels pump primes.
Is that right?
TIA
Is that right?
TIA
