1 Internal fuel tank pipes Mon Oct 07, 2024 2:34 pm
Skidmark
Hi forum
I'm resurrecting this 1989 k100rs and the original pump and all the internal pipes had dissolved and turned into black slime.
I ended up using a subaru forester xt fuel pump that I had in the shed and still have the inline filter, that works after I'd took the return valve off and cleaned out the corrosion.
I get the dribble catcher at the lid to drain away any fuel spilt but what is the other pipe?
It's near the front of the filler and is curled downward.
I put a bit of hose with a bolt in but this morning the bolt is in the bottom of the tank like was sucked out.
Thanks in advance.
Thanks in advance.
