1 Starting problem Tue Feb 18, 2014 12:34 am
RSMITH
Hi All
got a wierd one? K100 RT 1984
When I thumb the starter to start up the bike, the starter motor cranks momentarily and then nothing while still holding the starter button.
the fuel pump primes as it should- i can hear it.
if i repeat the process the same happens?
i got the bike to start- on one "kick" , but it did the same again after trying again.
Battery is good so i can safely rule that out-
checked all my main earth connection and positive connections to the batter , starter and on the engine - all good?
my thinking is perhaps the relay? does these bikes have one andif so where abouts is it located on the relay box.
many thanks
many thanks
1984 K100RT (Trans Karoo Express)
Set phasers to "fail"........................ If I were Britianna I would waive the rules.........
chasing echo's mostly.................
