1 K1100 - Tickover slows then dies, intermittent misfire, poor starting, loss of power, engine cuts in turns. Sun May 03, 2015 7:48 am
GerryP
All due to water in the petrol.
Quick check:
After engine has run for a couple of minutes open the filler and look at the petrol. If its cloudy (or in my case looks like bad milk) you've got watered petrol.
Cure:
Let the water settle overnight, put the bike on its sidestand and siphon using a clear 8mm tube into a jamjar with a metal top. Try to get the end of the tube right under the strainer of the fuel pump.
I got about a pint of water out and some interesting lumps of grot. No problems since.
I was lucky enough to work this out quickly but siphoning the tank is now on my yearly service list
Quick check:
Cure:
Safe riding ,
Gerry Parnham
K1100LT (1993) in Silk Blue/Cream
