1 Short-lived "loss of power" , intermittent yet v specific. Sun Sep 02, 2012 10:49 am
jonnyqq
Following Mr K2's shock at having the loose washer inside the starter he has done about 1K miles without problems.
There is approx 1-2 second loss of power,intermittent but I can now reproduce it as follows.
Firstly, only occurs after bike been on road for 10 mins or so,presume to operating temp.
Secondly, only occurs after sudden deceleration, eg after snapping throttle shut when changing gear. Revs sharply decelerate ,as expected , but when opening up throttle nothing happens, then suddenly power cuts back in (hang on Jonny I cried!) after approx 1-2 seconds.
Accelerates up nicely until next gear change or slowing down in traffic , same thing occurs .Otherwise , bike is running sweet and powerful.
I am aware of another similar post "engine cutout" which is really interesting so i apologise for troubling you again.
My attempts to fix thus far...
1. Replace fuel filter. Tank spotless inside.
2. Cleaned plugs,deoxit all HT connectors and all coil connections. (plugs 1-3 slightly oily, plug 4 sl grey).
Used just over 1L oil over 2300 miles.
3. Swapped ECU from salvaged Mr K to Mr K2.
4. Tank off, check for obvious loose connections.
Still got problem. Reading around above post i'm thinking about the relay box ,but as usual gentlemen the honest answer is simply once again that i havent got a #¥+<$*€ clue!
Therefore any advice would be most appreciated please. I am in The envious position of having Mr K to salvage bits from.
Time now to swap over to the humour section where i feel able to make a small contribution to ease my conscience for bothering the forum again.
Jonnyqq
Jonnyqq
