Go to page : 1, 2, 3 ... 23 ... 44
Topics [0]
![]() K75, interesting electrical phenomenaby jjefferies | 7 | 1074 | ![]() ![]() |
![]() How to get a cheap eBay Speedo to workby JacodAll of it works but the TGPI To hopefully save any future tin bums some time I have explained below how I managed to get the speedo to work. | 39 | 17978 | ![]() ![]() |
![]() Hall Sensor Plug pin descriptionby Rolf E | 15 | 1015 | ![]() ![]() |
![]() Mystery plugs in the relay boxby Jordan53 | 4 | 911 | ![]() ![]() |
![]() Can coils die of old age?by Clintinzso close to firing this thing up | 24 | 2159 | ![]() ![]() |
![]() Remove ABS module and wiring?by Nealchaykin69Turning 1985 K100rs into a cafe racer | 19 | 1208 | ![]() ![]() |
![]() fuel gaugeby GeorgeDaBikieWill the sender unit run a fuel gauge | 20 | 1951 | ![]() ![]() |
![]() Axel Joost Neutral Switch + M.unit and clutch switch woesby Harry.Dip | 19 | 1622 | ![]() ![]() |
![]() Trouble Starting & Runningby Keedo | 35 | 1715 | ![]() ![]() |
![]() Alternator[ 1, 2 ] by fishboy316 | 71 | 3560 | ![]() ![]() |
![]() Batteries.. again.[ 1, 2 ] by JaseYPKSmaller Batteries! | 56 | 6272 | ![]() ![]() |
![]() Spark plugsby Holister | 29 | 4630 | ![]() ![]() |
![]() BMW K75 dies out sometimes and wont start for a whileby PhillipRamboBMW K75C issue | 25 | 1753 | ![]() ![]() |
![]() Plug wire options?by BespokeVillainy | 11 | 2452 | ![]() ![]() |
![]() windscreen windshield motorby attituderepair of windscreen motor | 1 | 904 | ![]() ![]() |
![]() Hall sensors, Coil or just a loose/bad connection?by SunnyPerthvery intermittent drop of tachometer and power | 7 | 1263 | ![]() ![]() |
![]() Suspected Electrical Issueby Robert CrispBike won't run | 6 | 1096 | ![]() ![]() |
![]() Changing speedo from MPH to KPHby coopz1985 K100RS | 16 | 2883 | ![]() ![]() |
![]() Hall effect sensor HES tester test LEDby Dai | 3 | 1157 | ![]() ![]() |
![]() Fuel pump cutting out and a bonus mystery...by KEVVYMETAL | 10 | 1413 | ![]() ![]() |
![]() '92 K75 Intermittent Alternator (light)by jjefferies | 33 | 1336 | ![]() ![]() |
![]() 85 K100 Speedometer Issuesby Chris350 | 8 | 1692 | ![]() ![]() |
![]() Gremlinsby Pete RileyElectrical | 5 | 1009 | ![]() ![]() |
![]() Substitute HES pickup plateby Dai | 25 | 1952 | ![]() ![]() |
![]() 1985 K100RS. Newer style coil problem?by RS Rider | 4 | 1082 | ![]() ![]() |
![]() Strange Gear Outputby TheplayVikMight have overstretched voltage a bit | 5 | 1229 | ![]() ![]() |
![]() Starter no crank[ 1, 2 ] by OK1987LTNo crank, no neutral light and gear position indication. | 57 | 2337 | ![]() ![]() |
![]() Fuel light unit[ 1, 2 ] by Crazy Frog | 59 | 13941 | ![]() ![]() |
![]() While the bike sits it mysteriously drains my batteryby TSBT | 31 | 6011 | ![]() ![]() |
![]() A $15 Fuel Level Sender (sort of)by brianpen | 9 | 5185 | ![]() ![]() |
![]() 1985 k100 Fuse Boxby vividcolt | 1 | 1199 | ![]() ![]() |
![]() load shedby jercr77can it be eliminated? | 1 | 1263 | ![]() ![]() |
![]() hall sensor questionby jercr77voltage at sensor connection | 1 | 1150 | ![]() ![]() |
![]() I have crank, fuel, spark, and air flow. Bike won't even try to combust and at a loss.by Mooselet | 10 | 1435 | ![]() ![]() |
![]() No electrical powerby OK1987LTNo electrical power anywhere except Load Shed Relay | 24 | 1472 | ![]() ![]() |
![]() BMW Diagnoseby Ringfad | 6 | 1198 | ![]() ![]() |
![]() K75 Instrument Screen/Glass (but not)/mostly clear thingy...by NavigatorHow or where to replace the (cracked) screen on my instruments | 4 | 1079 | ![]() ![]() |
![]() K100 RS Dash Switchesby ShepDash Switches Held in Place? | 2 | 1153 | ![]() ![]() |
![]() Weird Speedo issue post fixby ark100Fixed the speedo in a previous post, have another issue and would to hear opinions. | 5 | 1416 | ![]() ![]() |
![]() Broke my speedo fixing my speedo. [Solved]by ark100I had a intermittent speedo (Wouldn't work until I knocked on the glass), disassembled for normal fix (3 pin) but now no speedo at all. | 21 | 2811 | ![]() ![]() |
![]() Fitting a Moronic to a 2v K100by Dai | 30 | 3772 | ![]() ![]() |
![]() Sticking Analog Gauges - voltage & temperature - fixable?by Bricklayer | 5 | 1062 | ![]() ![]() |
![]() Starter button bustedby club_c | 8 | 5405 | ![]() ![]() |
![]() K100 starter problemby JETstarer cranking engine slowly and disengaging | 8 | 1345 | ![]() ![]() |
![]() Self cancelling signals that don'tby klamityboy | 17 | 3636 | ![]() ![]() |
![]() FI relay not pulling in[ 1, 2 ] by Dai | 53 | 2653 | ![]() ![]() |
![]() Stalling after startingby boomhour86 K100 | 9 | 1142 | ![]() ![]() |
![]() Fuel Injector Tip stuckby DinosaurPartially removed injector | 2 | 1132 | ![]() ![]() |
![]() K75 Speedometer not workingby jjefferies | 15 | 1488 | ![]() ![]() |
![]() Applying brake turns my K100 offby OrdinaryRiderBMW K100RS 1990 | 11 | 1480 | ![]() ![]() |
Topics [50]
No new posts
New posts
New posts [ Popular ]
New posts [ Locked ]
