1Back to top Go down   Mystery plugs in the relay box Empty Mystery plugs in the relay box Mon Jan 08, 2024 6:42 pm
Jordan53
Jordan53
On my recently bought (last week) bike, there is under the fuel tank a lidded box with several relays in it.
Thanks to info I already have received here, I have identified the relays.
There are also 2 unconnected plugs for which I'd like to know the purpose.
One is white, with four connected wires.
The other is black, made for up to seven wires, but only six pins are connected in my case.
As pictures are not allowed here, can I in future link to an outside website with images?
Jordan
1989 K100 RS
1989 K100 RS
VIN: xxx0149621
2Back to top Go down   Mystery plugs in the relay box Empty Re: Mystery plugs in the relay box Mon Jan 08, 2024 7:26 pm
Black one is special equipment (radio for RT & LT models)
White is alarm
Mystery plugs in the relay box K75.K100.Early.Relay.Box.Wiring
3Back to top Go down   Mystery plugs in the relay box Empty Re: Mystery plugs in the relay box Mon Jan 08, 2024 7:31 pm
Jordan53 wrote:As pictures are not allowed here, can I in future link to an outside website with images?
Jordan
1989 K100 RS
Posting images will be allowed after a certain number of posts from you, along with access to the technical pages. This is basically done to eliminate - or reduce - those who arrive here only to gather info then piss off.
Another way to garner info for yourself here is to use the forum's search engine using either detailed or general/generic questions. This allows a search of the database - and the Google Gods arena - often without having to create a new thread.
4Back to top Go down   Mystery plugs in the relay box Empty Re: Mystery plugs in the relay box Tue Jan 09, 2024 5:57 pm
Jordan53
Jordan53
duck wrote:Black one is special equipment (radio for RT & LT models)
White is alarm
I saw this but missed the plugs.
Thanks Duck.
Jordan
1989 K100 RS
VIN: xxx0149621
5Back to top Go down   Mystery plugs in the relay box Empty Re: Mystery plugs in the relay box Tue Jan 09, 2024 5:59 pm
Jordan53
Jordan53
Two Wheels Better wrote:
Jordan53 wrote:Posting images will be allowed after a certain number of posts from you, along with access to the technical pages. This is basically done to eliminate - or reduce - those who arrive here only to gather info then piss off.
Understood, thanks TWB.
1989 K100 RS
VIN: xxx0149621
