1 Stalling after starting Mon May 15, 2023 10:57 pm
boomhour
I am just starting to run and test a bike after full teardown and rebuild (did not separate the head from the block). Everything you can replace was replaced by me or the previous owner within the last few years. I got it running yesterday for the first time and rode it around to test things out and get a feel for things. It ran ok and would idle at stops but the acceleration was lagging and then when I hit higher RPM's it would have more power. with the timing light I set the timing to about 6-8 degrees counter clockwise of default alignment. That seems opposite of what I've read here but that's how I got the bike to run. After my 20 minutes test rides I started fiddling with the timing and that when things went south. Oh, and I also ran it out of fuel but was luckly within a block of the garage.
today, I got some fuel and tried again. I can get it to start but it usually dies within 2-10 seconds after starting. I had it going down the road for a minute and it was lurching a lot.
It ran fine before tear down in August of 2022 and it ran well enough yesterday, but not good enough to be happy with it. I've not touched the the regulator or air flow meter screw.
previous owner had an issue with the fuel system enought that he installed a pressure valve inline with the return line and ended up replacing the fuel regulator. Fixed his issue but as far as i can tell the regulator is only a couple years old.
temp sensor, injectors, plugs, wires are all new.
Where should I start with diagnosing this?
- dry the plugs
- buy a HES tester
- replace the regulator....again
