Go to page : Previous  1, 2, 3, 4, 5  Next
View previous topic View next topic Go down  Message [Page 2 of 5]
Erman
Thanks, Inge.
Looks like this is turning into a full-on winter project. Luckily, we have lots of winter-time here in Norway Laughing
Sounds like a good idea to turn this into a winter project, since this is a rather major task.
Then you got more time to do a proper job, and can check the valve guides and seats.
It is used stretch bolts at the cylinder head, they can be reused one or two times......
but normally this kind of bolts is a one time use if you follow the book.
Erman
Erman
Thanks, will do!
What are the specs for keeping these apart from obvious damage?
Bikes:
1984 BMW K1000RS
1984 Yamaha XJ750 Seca
Don`t have any info on the cyl. head bolts used in our bikes.
What I said above is a general rule when stretch bolts is used.
Most manufacturers specifies one time use.
Others that they could be reused one time.
At last some have a very specific total length, which not should be exceeded.
Erman
Erman
The slow road back to roadworthiness - a blog - Page 2 QmIt's been a long while since I paused work on the bike. Today, it's finally time to get her into the workshop and start dismantle.
Bikes:
1984 BMW K1000RS
Erman
Erman
Yesterday I took off the tank to drain it for fuel, and found that it's easiest to do through the plug where the 4-pin sockets enters.
Also found that the original color of the bike was blue, as the underside of the tank was coated with this...
And so begins the dismantling process.
So far, this includes:
- Engine and drivetrain overhaul
- New tires
- Test of the Electrical system + repairs
- New seat cover
- New fairing on the front - streetfighter style
- Clip-on handlebars
Bikes:
1984 BMW K1000RS
good to hear that your getting time to play with the bike .....enjoy !
i just wonder ....there are far better candidates for street fighter style,
but hey ! most of us in here like to see different things and how they turn out... and we love our "k"s
good luck
Erman
Erman
Thanks!
The primary reason for wanting to alter the front, is that the bike came with a round aftermarket headlight which I really don't like.
Bikes:
1984 BMW K1000RS
Erman
Erman
After having finished tidying up the garage, I spent the entire last night dismantling my brick.
So far I've gotten off the following:
- a very rusty seat (overhaul is impossible, need new or single seat)
- tail, lisence plate holder, inner mudguard
- tank
- battery
and discovered that the bike is full of dirt and rust. Nice and cozy winter project..
Bikes:
1984 BMW K1000RS
Good start Erman
hope to see the results in Spring/Summer.
Keep warm
Erman
Erman
Got some pictures of yesterday's work:
The slow road back to roadworthiness - a blog - Page 2 8265191104_5bce5480f5_z
The slow road back to roadworthiness - a blog - Page 2 8265189354_41c2f37043_z
Also got the wiring off, as well as onboard computer(s), airbox, and exhaust.
I note that there has not been any work done on the bike for maybe the last 10 years.
Oh, and there was definitely seepage of coolant into the cylinders...
Bikes:
1984 BMW K1000RS
Erman
Erman
Ok!
After having looked somewhat amazed at how some people have (modded becomes too weak a word for this) sculpted their bricks into new works of art, my brain hurts with all the impressions I'm left with.
So I'm considering the following:
- Clip-on bars (already ordered)
- small fairing on the front (mentioned many times)
- cutting the rear and putting on single seat
- digital speedo (acewell or similar)
- getting rid of the airbox (is this possible?) (why is the airflow meter so big?)
- rider footpegs only
Also:
- right hand sidestand... (impossible?)
Bikes:
1984 BMW K1000RS
Erman
Erman
I managed to sodablast some parts during the weekend, for reasons stated below:
- Rusty
- Prepping for new paint
- Dirty
The slow road back to roadworthiness - a blog - Page 2 8278455638_0841356d1f_c
I have this setup for blasting:
The slow road back to roadworthiness - a blog - Page 2 471623_343869692326380_1285395628_o
Bikes:
1984 BMW K1000RS
Hi Erman
that stuff looks excellent. What size compressor do you use to get that result?
Can't wait to see your finished machine
Erman
Erman
RT wrote:Hi Erman
Thanks! It's a relatively small 3hp compressor with a 20 litre tank blasting away at 10 bar
Bikes:
1984 BMW K1000RS
Great progress Erman The slow road back to roadworthiness - a blog - Page 2 112350
The slow road back to roadworthiness - a blog - Page 2 Ir-log1188....May contain nuts!The slow road back to roadworthiness - a blog - Page 2 Ir-log11
K75RTP - 1994
caferacer62
caferacer62
Looking good now Erman...........Like that soda blasting.
Bert 2.0
The slow road back to roadworthiness - a blog - Page 2 170874
Erman
Erman
Have I understood it correctly if I believe the air inlet sensor regulates the amount of fuel to add to the mixture - so that if I were to swap the stock airbox with a cone filter, the mixture would just adapt to the change?
Bikes:
1984 BMW K1000RS
Inside the top section of the air box there is a MAF (mass air flow) sensor which is sometimes refered to as a barn door type.
You must retain that sensor for the system to work. The barn door is only on the 8valve engines and not the 16valve.
Erman
Erman
You mean this here?
The slow road back to roadworthiness - a blog - Page 2 K75smassairflowsensor_myk
Bikes:
1984 BMW K1000RS
Yep thats the item. It meters the air going in.
Erman
Erman
Next question (of which there will be many):
Footrests!
More specifically, some type of universal or adjustable mountings. Is there anything out there, or do I have to fabricate? Worst case scenario that I'm considering, is to cut the bracket in half, but that will still not fit my height.
Reason:
The seat as it sits now, is completely useless. It's rotted out and quite ugly. I want to make a new single seat, lowering it in the process. With my 186 cm, the current setup is a no-go.
Bikes:
1984 BMW K1000RS
Erman
Erman
I need better equipment if want to get this brick back on the road, so I went and made this blasting cabinet from some junk I had lying around...
The slow road back to roadworthiness - a blog - Page 2 8368925476_159da4564c_z
The slow road back to roadworthiness - a blog - Page 2 8368926632_fcb3a445df_z
Christmas lights, glass from a picture frame, 2x filtered bathroom ventilators,
sleeves from an old jacket, furniture wheels.
Leftover media collects nicely in the bottom.
Total cost 75 $
Bikes:
1984 BMW K1000RS
woohoo ...good inventiveness
good luck !
Brilliant!
Good thinking Erman - I'm interested to know if the Christmas lights are bright enough when the dust starts flying.
K75RTP - 1994
Erman
Erman
88KE wrote:Good thinking Erman - I'm interested to know if the Christmas lights are bright enough when the dust starts flying.
The top lights are very bright, but the other strip turned out to be for decoration mostly. Luckily, the fans drain the dust out in a matter of seconds. It's just enough to clean a part and take it to the workbench. When I come back, the cabinet is clear again Very Happy
Bikes:
1984 BMW K1000RS
Erman
Erman
I've done quite a lot of work during the weekend. Frame is off and sits by itself with all bolted-on parts removed.
Engine is lying on the workshop floor.
I stripped the front-right bolt which held the frame to the engine. Need to try to heat it later today. The plan is to drill the bolt, smooth out the crevice and use a nut+bolt combination when putting the bike together.
Also did the same to the swingarm bolt. Apparently, this one and the frame bolt have been in since the bike was built. A friend suggested cutting a slot and trying out an impact driver. Maybe I'll try heating it first...
Bikes:
1984 BMW K1000RS
Erman
Erman
Finally got the frame bolt out with an impact driver. Why on Earth did BMW design a threaded bolt on the right, and a bolt/nut combination on the other side? Evil or Very Mad
So the swing arm bolt remains... I've been struggling with it for over a week now. Drilling doesn't work - seems like there is a steel core (?), cutting a slot for impact driver didn't work - the material was too soft for the torque needed to drive it out, heating didn't work.
I can only hope that a workshop can get it out now...
Bikes:
1984 BMW K1000RS
Erman when you say swingingarm bolt do you mean the alloy bolt on the left side that has a 6mm socket head and a thread of about 16mm if so don't try till you get more info it is very easily damaged and VERY easy to damage the gearbox casing beyond easy repair.
Erman
Erman
Thanks Rick,
It is indeed the left side bolt.
Sadly, I've already managed to strip the bolt. Luckily, the casing is intact.
Bikes:
1984 BMW K1000RS
Well so long as the case is still intact.
What happens is that the thread is very open at the back of the case between the swinging arm bearing and the case. Grease is always there and so grit collects and as you turn the bolt out it picks up on the thread and jams the bolt and damages the thread.
I got caught almost the first time I worked on a K and had to turn the bolt in as far as I could then get a saw into the gap which is wide enough and saw through the bolt then the swinging arm came out.
Once out it was easy to fix things from the oposite side and the bolt came out.
Its a good idea to put heaps of grease in the space after you put the arm back in that way the dirt usually wont get into the thread. When I pull them apart now I clean the grease out and wash the area with petrol and then blow the area dry with air and turn the bolt inwards when the right side has been released and can come out a bit. That way the thread can be cleaned better as a wider gap is present.
If you have not got it out yet I would try turning it in with the right side released then you may be able to get to the thread. Its not an easy job to get into the bolt but the priority is not damaging the thread in the case.
Erman
Erman
Thanks again, Rick!
I finally managed to get the bolt out yesterday. I can't go into details, as I may incriminate myself in mechanical bike violence.
The thread looks indeed like you describe it. I'll see if I can improve it when I put a new bolt in.
Also, I started on the carbs. First soda blasted, then coated with Eastwood Metal Protect.
The slow road back to roadworthiness - a blog - Page 2 8412660075_155599aee1
Bikes:
1984 BMW K1000RS
Erman
Erman
Doing what I can to clean up the butterfly assembly:
The slow road back to roadworthiness - a blog - Page 2 8426921303_3632ed3824
Edit:
Changed the picture to the entire rack, cleaned and coated with metal protect.
Bikes:
1984 BMW K1000RS
Erman
Erman
The swingarm, cleaned and primed:
The slow road back to roadworthiness - a blog - Page 2 8426922495_908f80033f
Bikes:
1984 BMW K1000RS
Nice steady progress Erman The slow road back to roadworthiness - a blog - Page 2 112350
K75RTP - 1994
gmcq
gmcq
Looking good. Love the results of the soda blasting.
GMcQ
1996 K1100LTIC 0235790
Halo
Halo
Good one well done !
84 K100RS 0014803
93 FZR1000 EXUP
Erman
Erman
Finished cleaning and priming final drive and footrests.
I am really disappointed to say that one of the two allen-bolts keeping the rear brake disc to the final drive got stripped while trying to get it loose. Luckily, I don't have to redo the final drive at this point, as there is noe sign of failing gaskets or O-rings.
The slow road back to roadworthiness - a blog - Page 2 8432602969_2fd52f38b9
The slow road back to roadworthiness - a blog - Page 2 8433692152_a971043475
Bikes:
1984 BMW K1000RS
The slow road back to roadworthiness - a blog - Page 2 112350 ...................the brake disc screws is secured with Loctite,
and must be heated before removing.
Erman
Erman
Wow.. thanks, Inge, I'll try that!
Also, here is the soda blasted, but not primed gearbox
The slow road back to roadworthiness - a blog - Page 2 8453036436_a57506124b
Bikes:
1984 BMW K1000RS
Erman
Erman
Does anyone know in which way the stock muffler baffles the exhaust so that they become equal length (pressure) or is it even relevant?
Bikes:
1984 BMW K1000RS
have a look here erman
this might explain
https://www.k100-forum.com/t3968p150-time-for-a-tidy-up#49651
Erman
Erman
Thanks a lot!
A wee question awaits you on your own thread Laughing
I didn't get the time to work too much on the bike yesterday. Mostly thinking out stuff and placing an order to Motobins.
Had to fix a waterleak into our establishment's beer cooler, and did a little upgrading on the sodablasting cabinet to keep the dust inside.
Soda is reusable 2-3 times, but produces much more dust after 1st use.
I also managed to get one of the 20kg bags of soda wet. I had to lay it out to dry. Kinda looks like a whole different setting in this photo... (think Tony Montana)
The slow road back to roadworthiness - a blog - Page 2 8454577677_71843636fb
Bikes:
1984 BMW K1000RS
Erman
Erman
A few things since last update:
I got the color scheme set, but I don't want to divulge too much before lating the paint down Twisted Evil
The torx screws keeping the intermediary engine cover to the engine blocks are stripped - all but 6 of them. So impossible to get that casing off now.
I suspected they may have been set with thred locking compound, but the ones I got out showed no signs of this.
After looking at the water pump and exhaust ports, I noticed blue gel-like substance. WTF?
Bikes:
1984 BMW K1000RS
Erman
Erman
1 - Speaking of which, the said blue gel:
The slow road back to roadworthiness - a blog - Page 2 8484259099_651517bb11
I propose that it's coolant after being in contact with fuel...
2 - Another odd feature I noticed while looking at the engine's innards, the welded-on timing chain gear lower post:
The slow road back to roadworthiness - a blog - Page 2 8485363218_30af155f03
Wonder what forces could have caused this...
3 - Engine parts cleaned for paint. Notice a very small dent on the right side cover.
The slow road back to roadworthiness - a blog - Page 2 8484263381_169174bb69
4 - Engine and frame being soda blasted in the makeshift blasting chamber for large objects:
The slow road back to roadworthiness - a blog - Page 2 8484273401_2933156e7d
The slow road back to roadworthiness - a blog - Page 2 8485372322_c603bd1f96
I've now rotated the engine to the triangle mark at the hall sensor, and I believe this is TDC right? If I remove the timing chain and valve block this way, I assume the timing will not be affected.
Bikes:
1984 BMW K1000RS
mike d
Could it be Hylomar sealant?
Mike
Erman
Erman
Mike
No, I don't think so. Haven't used Hylo Blue this time around.
Bikes:
1984 BMW K1000RS
take note if the cam gearwheels marks are in the verticle up or down position...if in the up position it is tdc on number 1 ....if down it is tdc on number 4 (look at the valves if they are rocking to identify the correct rotation ) hope that helps ...
Erman
Erman
charlie99 wrote:take note if the cam gearwheels marks are in the verticle up or down position...if in the up position it is tdc on number 1 ....if down it is tdc on number 4 (look at the valves if they are rocking to identify the correct rotation ) hope that helps ...
Thanks!
Bikes:
1984 BMW K1000RS
Erman
Erman
Small update for tonight; got the engine and gearbox spray painted in black Bill Hirsch Engine enamel. Will lay on a second layer today...
The slow road back to roadworthiness - a blog - Page 2 8486015421_c500f8abe6_z
Bikes:
1984 BMW K1000RS
View previous topic View next topic Back to top  Message [Page 2 of 5]
