1 Ignition Problems Fri Apr 29, 2011 12:04 pm
Gardell
85 k100RT 102,000 mi, Very rough running when started, I kept it running while I pulled off plug caps 1 and 4, there was no change in engine. Plugs were wet, with new plugs I get weak or often no spark. Number 1 plug wire measures 3.5 k ohms and the others are 5.5-5.7 k ohm.
No signs of any external arcing when running at night. The coils are both open (> 2 meg ohms) between the high volt sides.
I have seen on this site where this should be 12.6 k ohm, I wonder why it runs at all. Also they are open between the high volt and ground, is this normal?
Do I need new coils and wire(s) or is the problem somewhere else?
New Hall sensor a few years back but I will try checking it with a LED when I get home.
Nice weather today, getting desperate, I am about ready to leave out 2 plugs and take it for a ride anyway.
