zonenfeile
zonenfeile
solved during Winter - OK - down under is the excepion
Ive done:
- Final drive changed to a rebuild one
- spline lubrikation
- New O-ring behind the clutch
- Sidestand switch now without worn wires
- Gearswitch changed
(my first atempt to repair the old one ended after 1/100 sec , leading to the awareness that I´ll not make a fool out of me chasing 5 micro splings an plugs in an chaotic garage)
- Oil complete new
- Starter with new brushes
- Generator as well
- adapting all lockcylinder to the ignitionkey
2012 - here we comeready for 2012 season ? what probs have you  723598
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
Go Olaf, good to see you've survived the winter.
I was thinking of undoing my gear switch, glad I didn't.
Large clear plastic bags were meant for the curious types out there. No not for putting over the heads of the curious types but for opening the switches in. My wife thinks I have a bag fettish. yeah right if only she knew.
zonenfeile wrote:
(my first atempt to repair the old one ended after 1/100 sec .....)
Bet that seemed like longer as you watch the springs fly in slow motion....NNnnooooooohhH 🐒 !
I repainted the front fork legs and disc centres, repaired the radiator surround fitted new tyres and repaired a tank leak this winter. Thankfully the spring days are looking better for a ride.
88KE
5Back to top Go down   ready for 2012 season ? what probs have you  Empty No problems, but . . . Thu Mar 08, 2012 3:17 am
bobgass
bobgass
I'm off from work next week and plan to pull off the back end and the transmission box to get at, inspect and lubricate the splines between clutch and transmission.
Bike is new to me (2 years ago) and I've done the easier-to-get-at splines, but I'm looking forward to seeing these deeper ones for the first time and having some 'peace of mind'.
Now if the highway department would just remove the sand, grit and salt that has accumulated on the roads, I'd be set to go.
I've read the 'how to's', read the Clymer manual, watched the YouTube videos and rehearsed the job. Looking forward to it, but will probably come back to the forum with some questions of my own.
Bob
walfish
walfish
Benifits are: a smooth clutch action(like new) and peace of mind Smile
Ghost who rides
Ghost who rides
No problems really or off season stuff ...but
Diesel oil and new filter as per forum wisdom .
Paint spokes black and polish rims .
Paint disc centers.
Paint front guard and rad cowl (thanks CF for the parts diagram )
To do .
Brake lines and master cylinder .
Lower screen.
Meanwhile , been riding the sweet triple , love it more each day !
zonenfeile
zonenfeile
Update:
Generator rubbers mounted wrong...
loud noise
dismounting the generator only possible if ABS2 Module is dismounted as well Twisted Evil
when mounting the hyd. tubes again I´ve killed 2 threads from the rear system,
Got a New ABS2 module from R1100rs - but didn´t work in the K
changing the software from R to K didn´t work with BMW Hamburg
now Ive changed the "brains" from the K Module to the R module
now it works just fine again.
good link to that prob:
ABS2 solutions
some pics from the operation
brain exchange ABS2
ex K1100/2
Olaf
Brickee
Brickee
Replace oil w diesel oil and filter
Replaced clutch disc, o ring and rear main seal
Replaced all radiator hoses and coolant
Checked cam chain for wear(looking good)
Installed LED lights to replace parking light in headlight per CF's post (looks impressive)
Synched TB's
Lubed all splines
Had to replace speedo after dropping it ready for 2012 season ? what probs have you  61740
Built rear fender extension. It doesn't look half as nice as OG's, but it's functional
Got in a creative(silly) mood and painted engine casings
And with the unusually warm spell we had a few weeks ago, I got in a few early rides! cheers
MT350Explorer
MT350Explorer
I'm scared to list it all lest the wife sees it... Very Happy
New exhaust and gaskets, new silencer support bobbin
Rear end strip down and repaint of frame
ABS brain from Tosi, fitted s/h ABS brain holder
New hazard rocker switch
New (s/h) ABS rocker switch
New tyre valves and wheel balancing
New coolant hose set
New fuel hoses
New grips
New ignition wiring harness (and grub screw)
New step plate (ignition barrel plastic collar thing)
Misc clips, screws for front mirrors and fairing, mud guards front and rear
Air filter element
New front indicator lenses
S/H 16 valve tool kit
S/H air inlet elbow and grill
Radiator mounting bushesNew tank and rear badges
Fibreglass repair to RHS lower panel
Aerosol respray of various panels
New front mudflap extender
New instrumrent green bulbs
Pair of s/h panniers
Seat refurb
To do
Fit all new rubber parts to rebuild throttle bodies
Balance TBs
New alternator bushes (might just keep a pair as spares - what do you think?)
And a MASSIVE THANKS to all those on the forum who helped me do it ready for 2012 season ? what probs have you  502531
Broke but happy
Dave
ReneZ
ReneZ
You're not too far away mate if you need help Very Happy
Rene
BMW K100 - 1985 (0030029) Scotland ready for 2012 season ? what probs have you  Rain
MT350Explorer
MT350Explorer
Thanks Rene, that's a generous offer I might well take you up on!
Best
Dave
