1 slide switch on right hand control Thu May 26, 2011 10:52 pm
Mindhaze
I just got another K100rt and there is a slide switch on the right hand control above the signal cancel switch. Does anyone know what this is for.
thanks
thanks
1986 k75, 1985 K100rt, |
Headlight relays have been installed on my bike for 10 years now. I use honking big 2.5 mm2 wire for feeding power to the bulb; no voltage drop in that circuit. I recently built a small PC card that replaced the separate automobile relays I used previously ( A description and photos of the circuit card is in this posting ).K-BIKE wrote:Hi Robert,
If you haven't already done so, give serious consideration to putting an Eastern Beaver headlight relay kit on your bike, it will help increase the headlamp brilliance, enable the use of more powerful bulbs and also reduce the load on the switchgear.
K100-forum.com » Technical, repair and troubleshooting » Electrical » slide switch on right hand control
Similar topics
