1Back to top Go down   Right hand light switch slider . Empty Right hand light switch slider . Fri Oct 28, 2016 11:40 pm
filastein
filastein
I trying to work out exactly were the ball bearing on the slider is supposed to go.
I wondering if there is supposed to be two ball bearings?
Any pictures greatly appreciated.
Cheers Fil
2Back to top Go down   Right hand light switch slider . Empty Re: Right hand light switch slider . Sat Oct 29, 2016 8:12 am
Right Hand Switch Disassembly/reassembly instructions
No, only one ball bearing required. You can see it on page 7.
3Back to top Go down   Right hand light switch slider . Empty thanks, great help Fri Nov 11, 2016 1:24 am
filastein
filastein
who would of thought , just one screw well hidden in the crud, would trip me up.
Sorry not been back earlier, up to me elbows in it.
Just need to realign the headlight this weekend and the brick is back.
4Back to top Go down   Right hand light switch slider . Empty Re: Right hand light switch slider . Sun Nov 13, 2016 5:40 pm
That's an excellent link with good images. When my headlight switched failed recently on my return home to OZ ride, I discovered that there wasn't any spring putting pressure on the ball bearing behind the headlight on/off slider. It had no 'detent' and would allow the lamp to blink intermittently. It's no wonder a few cars ahead of me moved aside as we passed. Who would have thought!?
I tried a small spring from a biro, a sleeve of plastic, etc., to no avail. Replacement was the only way to 'fix it' in the time we had. Thanks again to the brothers Grabau! Glad to hear, Filastein, that you're going to be going again.
5Back to top Go down   Right hand light switch slider . Empty Re: Right hand light switch slider . Mon Dec 05, 2016 10:49 pm
rawdonball
rawdonball
I'm tagging onto the end of this thread as I have my right hand switch assembly coming to pieces as a result of being at a loss as to where to go next.
My problem is a u/s rear park light / tail light. Bulb and holder check out ok so I separated the plug at the rear and confirmed no power getting to the upstream terminals in the plug half.
Front park light works so I need to find places en route from switch assembly to rear plug where I can check for continuity and hence narrow down the area in which the open circuit must be located.
Any help much appreciated...
6Back to top Go down   Right hand light switch slider . Empty Re: Right hand light switch slider . Mon Dec 05, 2016 11:19 pm
The only access point is the switch plug under the tank, other than that it is to open the harness.
7Back to top Go down   Right hand light switch slider . Empty Re: Right hand light switch slider . Mon Dec 05, 2016 11:57 pm
rawdonball
rawdonball
Cheers Rick - will keep you posted.
Hope you are keeping well? I thought of you as I came up from Sydney through Glouster, Inverell and Texas. In Toowoomba now.
Have the stalk mirrors surfaced yet ????
8Back to top Go down   Right hand light switch slider . Empty Re: Right hand light switch slider . Tue Dec 06, 2016 1:30 am
I am in Barmah in Victoria ATM
