1Back to top Go down   Dicky indicator switch left hand side Empty Dicky indicator switch left hand side Fri Nov 22, 2013 12:58 am
fender22
fender22
Hi all. Seem to have developed a problem with my left hand indicator button. I can still make it
work with a bit of fiddling around but obviously something insidde the switch has let go.
Is it worth pulling apart. Can I buy the switch on it's own or am I up for a complete control unit
on the left hand side
Yes you can pull them apart, most here will tell you to do it in a clear plastic bag so as not to loose any of the fiddly bits, usually a bag big enough to stick the whole unit in along with your hands probably from both ends with a screw driver and small beaky nose pliers, you can check through the old posts via the search function for others who have done it before, and you can visit the bm shop as they would have anther unit there ready to go if you chose to take the easy way around the issue, sometimes just soaking the unit in cleaner can remove the verdigrease that has or is stopping the unit at present, maybe even drown it in wd40 or onix whilst operating the switch will clear some of the crud away to restore its use.
You can take these apart easily and (correct me if I am wrong) there's nothing in the left switch that will turn into a missile...but take precautions like Keith suggested.
You will probably find that it's only dirty contacts. Clean them up, apply DeoxIT red (note the
spelling Very Happy) and all will be good. DeoxIT is available from any Jaycar shop.
No doubt that WD40 will be a help here, but I have found Lanotec Heavy Duty Liquid (spray can) is very good stuff. Alby reckons it smells like stinking, wet sheep. He uses it as an aftershave or so I've heard!
Get it from Supercheap Autos for around 12 bucks or so.
If you have any problems, post it and we'll see what we can do.
Last edited by blaKey on Fri Nov 22, 2013 3:57 am; edited 1 time in total (Reason for editing : fat fingers...)
lol!
Yep thats a problem with shaving for sure, I myself have a phobia of razors.
Forgot to mention...you can still buy the yellow "paddles".
Albyalbatross1
Albyalbatross1
blaKey wrote:+1.
It does....smell like stinking wet HOT sheep..(memories of growing up working in shearing sheds  in QLD outback!) and yess...I use it as a deodorant,aftershave,skin care,mouthwash,eyeball polish..
Yes the switch is easy to pull down. there are fine springs!! take note of screws locations..
Bit Me Blakey!!!!
If you want new switches I bought one for each side from Motobins in UK for about 1/4 of the price the BM Shop in Brisbane quoted and Munich Motorcycles were a tiny bit cheaper than BM Shop but said they were not available any more but he may be able to get a new old stock. (he buys a lot of his parts from Motobins and Motoworks in UK).
