Number of posts : 4427
keithnh wrote:Laitch .. I see the ebay used .. tried one already and sent back as start switch was broken and looked ready to fall apart, would prefer new part if I can find the right one for this item. Found a new 233(last 3 digits) that looked correct for 150$. Was curious about fit and functional differences in parts that appear identical. Guess I will pull old one before I order .. thanks for input.
duck .. thanks for input .. looking at fiche numbers seemed far apart for 2 I listed, couldnt fin the 233 applying to a different model .. confused abit .. is the 233 the US model for 85 k100?
The 233 is the always on(continuous) switch for the later 4 valve Ks - K100RS4V, K1 and K1100. The 464 is the always on switch for K75s and 2V K100s.
The switch assemblies are exactly the same for both but they have different connectors.
The early 2V Ks have a white square 9 pin connector while the 4V Ks have a black rectangular 12 pin connector.
