1Back to top Go down   Front crank seal dimensions Empty Front crank seal dimensions Wed Mar 31, 2021 10:50 am
nino
Hello, anybody to send front seal dimensions. That seal behind hall sensor slightly leaks, Thanks
2Back to top Go down   Front crank seal dimensions Empty Re: Front crank seal dimensions Wed Mar 31, 2021 11:05 am
nino wrote:Hello, anybody to send front seal dimensions. That seal behind hall sensor slightly leaks, Thanks
You only have to look it up in realoem.com or other online site. BMW often shows dimensions for seals and for bearings. It's current OEM part number 11 14 7 654 531 and measures 52x36x7.
3Back to top Go down   Front crank seal dimensions Empty Re: Front crank seal dimensions Wed Mar 31, 2021 12:39 pm
Also, buy an original seal.
4Back to top Go down   Front crank seal dimensions Empty Re: Front crank seal dimensions Sat May 25, 2024 7:16 pm
I've discovered I need one for Big Block. Over US$20 from the dealer, but the local professional bearing & seal shop has a European-made SKF brand for under a tenner. Easy choice. Too bad it's Memorial Day weekend and they're now closed until Tuesday.
