Go to page : Previous  1, 2, 3, 4, 5, 6 ... 12 ... 20  Next
View previous topic View next topic Go down  Message [Page 5 of 20]
its just down the road from me alby ..well 3 corners away.... just the other side of the archerfield airport ...will do ...wont be till friday though ....off to mt isa this week
ahhh !!! got to love it ....turn on and the meter jumps to the right setting ....woohoo ...lets hope the calibration for the sensor is the correct type .
at least i got a 4 watt globe behind this one ..and it works ....yipee
heading up the road for a test ...and a meet at fernvale ...with alby
hmm reads a little high ....110 when it should have been 85 or so ...
i tried putting about 90 odd ohms in series with the sender ...seems to be closer to the mark
the sender for bmw reads about 78 odd ohms at about 80c temp and the additional 90 odd would make it about 160 or so for the aftermarket autometer one ...unless there is different senders ....which i read about on their site ...as being no longer available ....
iguess this might affect the linearity ...but ill wait till the thing cools down for further testing
wish i could find some more correct data
Oldgoat
Oldgoat
Hey Mate,
I'm going out to the dealer Mon. or Tues. and I'll talk with Jim and see what he knows/recommends. Sorry it's not been sooner just been working my tail off and haven't had a chance to get out there...
OG
thanks for the thoughts og ....hey no hurry here at all ...cheers mate ...and dont forget to get some quality time for yourself in amongst all that rushin around huh ?
order in for injector refurbish kit ....comming by post
just noticed ...after spying the sticky clutch arm thread ...my bearings -shaft is locked solid ...maybe i just need to tap harder ...and replace those pivot bearings pretty soon .
new style centre stand off for modification, old one back on ....a borrowed tyre will get me to karuah and back next weekend (thanks GIH)
Oldgoat
Oldgoat
How you gonna flush em mate?
oh...! we have the ic3000 now og .....
the kit includes filters and seals for all over ...
carbi cleaner ....and a trip up to kingaroy might be in order for the ultrasonic bath treatment
when we do our next workshop day i guess og
working on a couple of new inovations for the ic 3000 between now an then
and an old ford injector loom
Oldgoat
Oldgoat
Nice mate! Cool
Avenger GT
Avenger GT
"just noticed ...after spying the sticky clutch arm thread ...my bearings -shaft is locked solid ...maybe i just need to tap harder ...and replace those pivot bearings pretty soon ."
Is the shaft turning with the clutch arm Charlie? If so it is probably corroded to the arm between the bearings, and no amount of tapping will shift it. I had to sacrifice the clutch arm and cut the shaft with an angle grinder on a K75. Better than breaking the mounting lugs off the back of the gearbox!! Just for the hell of it I tried to shift the remainder of the shaft afterwards and there was no way it would move.
the arm pivots ok avenger ...but under load seems real gravelly ....
yes you could be right ...that corrosion has bound the whole shooting match ,,,,
in another thread i had spied a few fellow members with a grease nipple fitted to the arm...
seems a real sensible idea
but pauls teflon mod seems to make sence ...my thinking is it there is nothing in there to corrode away (the whole arm pivot is flooded with teflon except for the pivot bolts /pin )
the action is still somewhat good ...but i think ill prepare for a refurb ...
thanks for the info ..i recon i better look around for a spare
charlie99 wrote:in another thread i had spied a few fellow members with a grease nipple fitted to the arm...seems a real sensible idea ..i recon i better look around for a spare
Motobins got a set, with pivot pin (stainless?) and grease nipple fitted...Part No.31870...(exchange part).
Last edited by Inge K. on Sat Feb 04, 2012 10:58 am; edited 2 times in total (Reason for editing : Adding info)
thanks inge ....ill go have a look ....cheers 85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 112350
wow 52 pounds ..... hmmmm serious thinking now
Albyalbatross1
Albyalbatross1
charlie99 wrote:oh...! we have the ic3000 now og .....
I may have found a simple solution to that upgrade for IC300.. We will need the ford loom..Not going to cut into K one!!! and the fuel pump from ford as well!!
already got the pump alby ....nice low power job ....(32-35 psi easy ) just have to find a regulator thats cheep at 32 psi and double ended ...just about all the ones ive seen are bolted to fuel rails and dont look like they will adapt well to rubber hose at both ends ..
just back from sampsonvale (picking up a suzi pe 250 frame for ma brother )
off to see bert 2.0 and do a few checks on the way ...big ride comming up
Albyalbatross1
Albyalbatross1
I have a fuel rail we can use. You going south..Got water wing????? Very Happy
Albyalbatross1 wrote:I have a fuel rail we can use. You going south..Got water wing????? Very Happy
lol probably need a couple alby ....grin
injector kit arrived ...will look in the pack when i get back
heading over to bert 2.0 s place today ...the bike still looking in a dishevelled state after the karuh river ride ;
fingers crossed
wash time later
Oldgoat
Oldgoat
Hey Chaz did you guys get any pics of the ride?
OG
you didnt see og ? hang on ill get the link
try here mate http://k100rt.aforumfree.com/t3160p50-karuah-river-rally#30287
Oldgoat
Oldgoat
my bad mate. thanks!
Oldgoat
Oldgoat
OMG! that stream crossing on the K is classic...that's going up in my garage!! Cool
glad you like em og ...i had taken a few more ...but when the camera is low on batteries they dont always save ....maybe im too quick on the shutt down as well
got the centre stand fitted up ....and a fantasic job by bert 2.0 (caferacer) pics to come
i have to clean the old beast up some first i guess
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 2012-027
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 2012-028
Oldgoat
Oldgoat
Nice! I'm looking forward to how you guys solved that one as it's really the last snag on the road to modern rubber! Very Happy
Oldgoat
Oldgoat
Hey mate I forgot to ask...you running the stock alternator with those driving lights?
yes mate their only 50 watt globes in each ...so all good ...i ussually use them as day time, coming into traffic running lights .. was thinking i could actually take them back to 35 odd watt types as they are more a be aware type indicator forward ......although at night by myself they do add a lot of fill to the road in front
so i guess my quota for current draw is about 20 - 25 amps
and im comfortable with that ....
if i was adding 100 watt (each lamps) i would be heading for the 50 amper altenator
their switched by the cutout whilst starting circuitry too
Oldgoat
Oldgoat
Smart man & I like it...I'm still trying to figure out a suitable way to mount my old IPF's onto the old girl.
just a little bit later
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 Pics_013
and the new centre stand modified
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 Pics_010
i have to say i had an extreemly crappy clutch moovement just lately ...and thought to myself that the clutch arm bearings were rats**t
any how.. turns out ...i found a fine film of powdery white plastic at the lever end ...hmm whats all this about ?
i figure that the new clutch cable that i installed just recently ..had been sitting for quite some time ..as a parts backup (pitty i didnt keep the label off it as i installed it it may have contained production date etc )
well i guess the internal "teflon coatings" (which i doubt ....maybe silicon based ..plastic crap ) had deteriorated quite markedly ..tends to happen in our area of high humidity and temperatures ....which makes me think it was a more polly propeline based liner ...
anyhow the effect was quite like a grubby ..dried out bearing pivot bearing ...the feel was like a grabby , tight pivot ... io drilled the pivot arm (although there were no restriction that i could notice throughout its moovement ...unloaded and loaded ) and pumped it with some lanotec .
i suggest if your testing this you have a third hand available . thanks bert 2.0
any how i bought one of those "cable lubrication injector clamp" devices to inject some teflon based product down the core.
guess what ...yep no result at all after swampng it with the good stuff ...and allowing it to dry ...
i ended up using the lanotec product ( highly unadviseable on modern cables ) ...and it came smooth ...but maybe not for long ...the deterioration is onset and prolly going to get worse over time ..
ill order an replacement (hopefully newer version in the near future )
bugga ...!!!
but the clutch is "as smooth as" now ...well for while
Albyalbatross1
Albyalbatross1
I really like the look of that easier to use stand!! I also still jealous of shiny exghaust pipe!
Oldgoat
Oldgoat
Nice work on the stand mate! Cool I'm going to have to start rat holing funds for Kosman...
caferacer62
caferacer62
Albyalbatross1 wrote:I really like the look of that easier to use stand!! I also still jealous of shiny exghaust pipe!
Hey Alby as soon as i get a chance we will get one of those shiney pipes on yours too. bounce .
Bert 2.0
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 170874
did a little exploring through the wreckers yard ...and found ...6 nice and tasty injector connectors ....puuurfect for the ic 3000 project
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 Pics_014
bagged up and ready to send up to alby ....oh i better get that pump out too ..
charlie99 wrote:did a little exploring through the wreckers yard ...and found ...6 nice and tasty injector connectors ....puuurfect for the ic 3000 project
That is soooo weird.. I did exactly the same thing yesterday ... rummaged around a wrecker's yard looking for injector connectors ... as I'm reconditioning my injectors and needed the connectors for the test bed. Picked up a set from an eighties Opel which had been front-ended.
Oldgoat
Oldgoat
Lol, you boys are hard core! Shocked
Nah they're just a bunch of skinflints OG, like me.
Every dollar I save lets me ride another 12km. 85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 723598
K Freak wrote:Nah they're just a bunch of skinflints OG, like me.
+1 85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 112350
Oldgoat
Oldgoat
Lol, sounds like a pretty good formula to me K!
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 112350 85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 44271 too funny !!!
i cant help the way im bent ,,,giggles
"Every dollar I save lets me ride another 12km"
Never thought of it that way.
You are a very wise man K Freak!
it never rains but it pours ......
well today ...first day back on the beast for a few weeks ....blooming fan decided to chuck it in ...
i guess its all that inactivity and the damp weather weve been having of late
investigation will be on saturday ....but im mildly peeved ....
a quick inspection saw the fan ....well not siezed..... but hard to turn
oh well it had to be done ...i guess itll be out on the ground come saturday lunch and a full dissassembly is in order i guess , a cleanup of the armature and bearings , brushes etc ....just hope i haven't burnt the contacts off the fan relay device ...
fingers crossed
Bit of bad luck there Charlie!
I hope everything works out well for you.
thanks neil ....i guess it really doesnt stop the whole shooting match ...but takes away the safety margin ..knowing that a failsafe device aint right .....just my luck huh ?
Bad luck Charlie - I'd be peeved too ! With your skills it won't be out of action for long!
88KE
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 Ir-log1188....May contain nuts!85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 Ir-log11
K75RTP - 1994
thanks 88 ....you know really i shouldnt be so disheartened ....for without the forum ...i never would have put in my bypass - fan activation switch ....which in turn lets me excersize the fan and keep temps down when needed .....rather than finding out ...with quite dramatic results that it didnt work ....right when i needed it to
cheers you guys
Oldgoat
Oldgoat
The bright side is at least you were out on the old girl mate and I'm sure you'll have the darn fan sorted out quickly.
Oh, and the modded center stand really turned out nice! Cool I've got to find time to get mine off to "fix" it and also want to do Paul's padlock mod as that is one of the best little tweaks I've seen!
OG
Rick G wrote:Nah they're just a bunch of skinflints OG, like me.
Just done some maths....... we only get 8.5 Km to an oz dollar.(67p). Sad Oh for the days when we got 4 gallons for a £.
well lucky me ...the motor operates quite well ....after a little lubrication
but the connectors ,,,,as usual..... look corroded
just waiting for the deoxit to do its job before chasing the wiring back to the temp relay controller
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 Pics_016
charlie99 wrote:well lucky me ...the motor operates quite well ....after a little lubrication
Not to much of Marvells mystery oil...Charlie...you may have a take off.
Congrats with the result.
started on my brake light mod just this week
things are looking prommising
the basics ......i thought of adding some extra lamps in the external part of the taillight housing  ...just to the outside of the lens assembly area ...the main globes kinda fit in a boxed section in the centre of the lens base ....and i have been noticing that at wilst mooving any help to get extra illumination would make sence to me
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 2012-030
so i got some 4000 mcd 10 mm red leds (some while ago ) but got bored and decided to make them up
i mounted them in some vero board ....to line up with the lense high spots
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 2012-02985 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 2012-011
a diode and a current limit resistor was employed with the leds in series
soldered up ok and coated with clear acrylic laquer to protect the connections
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 Pics_01785 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 Pics_011
man these things are bright for just 20 milli amp of current
85 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 2012-03185 rt resto ...my attempt ...hey im not into making a show bike ... - Page 5 2012-012
more to come as i get them mounted up
View previous topic View next topic Back to top  Message [Page 5 of 20]
