Number of posts : 7968
RicK G wrote:Don't go throwing money at a problem until you know for sure where the problem is. The Hall sensors are a likely culprit along with the coils.
Go to the portal page and look for a guide on testing coils and sensors it could just save what hair you have left.
Either Hall Sensor or a coil causes 2 cylinders to drop out.
The rev counter is attached to one of the coils.
Simple test is if you can by feeling the headers decide the 2 cylinders that die, its either 1/4 or 2/3, then change the coils over. They are interchangeable.
If the dud cylinders stay same, its Hall sensor, if dud cylinders change to follow the coil change, then its the coil is your problem.
1971 Yamaha 125 YAS-1
